Bike Identification
Tags: None
From all that I see, a Standard (G model I believe) with a Special tank.Life is what happens while your planning everything else!
78 XS750 -
standard or special?
I believe it is a standard,with special tank note seat tank junction!
Note non leading axle forks Also I don't think Special ever had square gauges or turn signals Can't tell rear wheel size.... 17 inch would be a standard.
Joe78standard,79 & 80 Specials; 2 x 650 Maxims; 4 x RD350's; yz450; 2 x Honda tlr's;2x jt1 mini.Comment
Yes, the front end, headlight, gages, turn signals, rear foot peg brackets, and seat point to Standard. Now that I see the rear seat cowl, I believe that would make it 78 or 79.Life is what happens while your planning everything else!
78 XS750Comment
+1 on a standard. If the seat cowl is indigo blue, I'd say '79 F. Lookk at the forks, no leading axle, more evidence of a standard.79 F
1967 Suzuki X6 Hustler
1973 Suzuki TM 125
1979 XS1100 F
2005 Kaw. Vulcan VN800
1991 BMW K75Comment
Also, if the bike runs pretty well, buy it, get fenders, side covers, and it will look sweet.79 F
1973 Suzuki TM 125
1979 XS1100 F
1991 BMW K75Comment
I agree with everyonestandard with special tank...VIN#would tell us the year
recently I had to play this game with xs owner who was selling motor ... he was under impression that he owns '81...but with VIN starting with 2H7000xxx...not so muchNick
1982 Virago 750 (it's alive!)
1979 XS 11 F, Windjammer IV, Samsonite luggage cases(another rescue)Comment
First thing I looked for was the kick starter plug. That kinda looks like the kickstarter shaft, with Jardine alphabet mufflers? I'll wage a guess and say '79.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
P.S. Was that bike hit? Front-end looks crooked.1979 XS1100F
1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors)
Sometimes it takes a whole tank of gas before you can think straight.Comment
if it's a bargain - - - ? Thing is, XS11 parts swap like LEGO so although for sure it's a Frankenbike, what did it start as?
Check the frame ID. Check the engine ID too.
Compare those against the year/model list that's on here someplace.
And against the IDs on the registration.Fred Hill, S'toon
"The Flying Pumpkin"Comment
