Riding a naked Excelsior!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    Today when I got home from work, I decided to remove my fairing to kill an electrical gremlin I'm my ignition connector... Ended up being a rotted out female spade...
    Then I decided to remove my hardbags as well.
    Then put my old headlight back in, with the HID.
    Removed the calipers, painted them, as well as my swing arm, and final drive.
    I haven't ridden Excelsior nude like this, since before it actually ran good.
    Oh my! Soooooo much lighter, and more agile. Woo!
    I might get in trouble around town with Excelsior setup like this.
    One thing I did notice... Riding without a shield... When you hit 60..the wind, causes my head to like... Drift side to side... So weird.
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    • 8864
    It looks good that way.
      • 3932
      I like the COLOR!!! I see some low-profile bars, stock seat, tank & side cover badges in your future to make the bike look really fast!
      • sparkfly88
        • Mar 2013
        • 585
        • CedarKey FL
        The previous owner did that....
        I reversed it all
        Stock seat pan is rusted through... The rear end was chopped off and was rewelded back... Then they had flat bars on which dented the tank..
        79F
        "Excelsior"
        Hid headlight 6000k
        Stock jets
        Shinko 712 F & R
        TC fuse block
        Raptor 660 Acct
          I reversed it all
          Hi sparkfly,
          like in another activity, naked is the best way to ride.
          If you are unhappy with your double bucket seat and want to fix up your rusted out factory seat pan
          get it sandblasted then put a 1/8" thickness of fiberglass on it's top surface to restore it's strength.
          Never mind how your bars look, the only thing that matters is how well they suit your preferred riding position.
          But me, I'd do something about the tank badge mounts.
          Put replacement badges on or bondo them in smooth and perhaps a decal.
          The way they are now looks kinda unfinished.
            • 5069
            The battery tray itself is plastic. The brackets are steel and are prone to rust due to off-gassing of battery acid as possibly boil-over from excessive charging.
            I would remove the fuse panel (good to upgrade also) and clean the contacts for both the four-wire clip and the two-wire clip to the alternator. I am not blaming the overchanging on that, but it is a real good thing to improve contacts there.
            The thing about rust is that it leads to more corrosion. Hopefully the fork pipes are pristine.
              • 5069
              One more thing... There are some errors in the Clymers manual like torque on the swing arm adjustment and I believe there is a mistake on the example for adjusting the shims.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                Shims on the swing arms? What are you talking about?
                Really the only rust was where the rear fender was welded back on... The chrome by the headlight has surface rust... It doesn't bother me.
                It's a daily driver that stays outside under a bike cover. Not a show bike.
                I have the oem manual that is in the website everyone seems to know on here. I tightened the whole front end to spec.
                The badges don't bother me.... Yet.... Because it needs paint, and the tank insides redone.
                Just wait till you see my next couple videos... Whole reason I took the touring gear off is so I'm lighter for this upcoming trip... Excelsior is going to see forest roads. I'm gonna gopro it all, my practice sessions are going to be on a sand road my friend owns.
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  • 6762
                  Wow that looks really nice...why do you need a fairing living in Fla? Bike looks so much better naked...
                    • 6762
                    he is talking abt 2 separate issues...
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      Did my photo show my bike had issues somewhere?
                      Also... Riding like this, makes me feel like I have no front end... Like I'm floating... It's kinda strange. I'm used to my huge fairing being there like as a "This is the front end of my bike" now.... There is just nothing. Lol
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                        • 5069
                        Nakid bikes are way more "flickable" in the twisties. No fun on long interstate rides... The only solution to the problem is that you NEED at least two xs11s: One nakid and one fared.
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          LOL, at last, some entertainment.
                          When you get back, you can share with us the ways to get an 11 back on it's tires.
                          Videos of that exercise would be nice. Especially the sand road.
                          If you can get some knobby's, I would recommend them, fore and aft.
                          CZ
                          • Cobia
                            • Jul 2007
                            • 1587
                            • Palm Beach County, Fl
                            Sparks,
                            If you're going to be doing some highway driving I do suggest adding a windshield. It will prevent a lot of fatigue.
                            1980G Standard, Restored
                            Kerker 4 - 1
                            850 Rear End Mod
                            Automatic CCT
                            1980GH Special, Restored
                            '82 XJ1100 (Sold)
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              I plan to put the handlebar mounted one back on for the highway ride there
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
