EBC Clutch Tool for 1980 XS1100LG
  • Tenorman
    • Oct 2013
    • 70
    • Butler, Penn.
    Hello all,
    Does anyone know if EBC makes a clutch tool for the 1980 XS1100LG?
    If so, what is the number of the tool?
    Many thanks and best regards....
    Tenorman
    Bikes that I have owned and enjoyed...
    1964 Allstate 250
    1970 Yamaha DT1
    1959 Mobylette
    1970 Yamaha JT1
    1995 Suzuki 80
    1978 Yamaha XS650
    1980 Yamaha XS1100LG
    2005 BMW R1150R
    What are you trying to do that you need a specific or special tool for? All of the mounting hardware is typical nuts and bolts.
    • Tenorman
      • Oct 2013
      • 70
      • Butler, Penn.
      Thanks for your reply....
      Thanks for replying to my post...
      I'm going to replace some of the gears in the transmission and I would like to use a clutch holding tool to minimize the chance of breaking the basket...
      Also, If there is a tool available (at a reasonable cost), I would prefer to use the correct tool rather than jam something in the rear wheel (particularly when re-torquing the nut).
      (No offense to those who jam something in the rear wheel).
      Thanks....
      Tenorman
      1964 Allstate 250
      1970 Yamaha DT1
      1959 Mobylette
      1970 Yamaha JT1
      1995 Suzuki 80
      1978 Yamaha XS650
      2005 BMW R1150R
      • DAVINCI
        • Jan 2011
        • 1048
        • Cedar Mountain, NC
        No offense taken. But, there is a wedge cast into the engine case made for inserting a screwdriver, to hold the driven gear ( or the mainshaft gear? been a while). I've used that with good results, too
          Rod posted a pic of that boss not to long ago. It is by the primary shaft gear that drives the outer clutch basket. Personally I use the rear brake to hold the wheel and granny when I tighten the clutch nut.
          • Tenorman
            • Oct 2013
            • 70
            • Butler, Penn.
            Thank you....
            Thanks for replying...
            I think I did see that photo...
            I'll check it out as I haven't made it into the transmission yet...I'm still rebuilding the calipers and master cylinders...
            There's no big hurry because the last time I looked, it was just 21 degrees outside and that's a bit to cold for riding...at least for me....
            Thanks again....
            Tenorman
            1964 Allstate 250
            1970 Yamaha DT1
            1959 Mobylette
            1970 Yamaha JT1
            1995 Suzuki 80
            1978 Yamaha XS650
            2005 BMW R1150R
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              Here's one at wal-mart for $24
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
                • 8962
                I bought one of those tools 20+ years ago and it bent into a pretzel, you are probably better off using one of the methods mentioned above, they work every time. An impact gun should do the trick.
                  Parts-N-More offers this one.
                  Mike's XS offers this one.
                    Wow! I didn't even know there was a tool for that, or that anyone thought they needed one.
                    • Tat2demon
                      • Jun 2012
                      • 718
                      • Sioux Falls, South Dakota
                      Ive pulled the clutch on mine three times and still dont understand what those tools would be used for.
                      Nate
                      78 XS11 "Matilda" 2H7 000364
                      K+N Air Filter
                      88 Voyager XII
                      81 XJ650 Maxim
                        • 8962
                        They are to hold the clutch from spinning while the engine is out of the frame on the bench for disassembly.
                          Ha ha.....thanks for the clarification Phil.
                          we are being facetious.
                            • 8962
                            Yep, I should have known that.
                            • Tat2demon
                              • Jun 2012
                              • 718
                              I wasnt, had no idea.
                              Nate
                              K+N Air Filter
                              88 Voyager XII
                              81 XJ650 Maxim
