Cured the low end stumble finally!
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    For the longest time I've been messing with the fuel system trying to get rid of this low end load stumble..
    Taking off from a stop it'll stumble a bit, and while cruising.
    Synced and colortuned to a little richer from Blue as normal... And running NGK bp6es. The NGKs have like 4k miles on them.
    Well last night I decided I'm gonna try something. I colortuned it to the cobalt blue, and changed the spark plugs to autolite platinum ap63.
    Wow! What a difference. Smooth idle, smooth cruising, and no stumble at any rpm.
    Woo!
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
    Woo!
    Well, since you performed the cardnial sin of changingtwo things at once, guess we'll never know which resolved the issue. But, good to hear it's resolved either way.
    • CaptonZap
      • Jun 2010
      • 1748
      • Denver
      Hey Brant, why don't you convince him he ought to re-install the NGK's, and see if that returns the stumble?
      CZ
      • jjz28
        • Apr 2012
        • 1023
        • Beckley, W. Va.
        CZ
        Exactly, that is what I would do. It would be nice to know if the plugs or the tune was the culprit.
        77 XS750 2D completely stock
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          Well, the stumble is back....rarely....but noticeable
          poop
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
          • TADracer
            • 1417
            • Kenner, Louisiana USA
            Well the heat range of the BP6ES and the AP63 are exactly the same (stock) so the only thing the platinum plug could be contributing is an improved spark kernel (and that is debatable). Give a hotter plug a try (BP5ES) as my machine sometimes likes a hotter plug.
            I think the cause of any stumbling lies elsewhere.....valve adjustment, ignition timing, vacuum advance mechanism, less than squeaky clean pilot circuit passages, etc. Remember, setting the idle mixture to cobalt on a color tune only affects the motor at idle. As soon as you crack the throttle you are basically off of the idle circuit and onto the pilot circuit (though the idle circuit feeds from the pilot circuit).
            Mike Giroir
            79 XS-1100 Special
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              Well, ive already redone the advance system, valves are adjusted..ignition is timed, carbs are spotless many times over...
              My next plan of attack is the pinholes in the diaphragms and new coils.
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
                • 4015
                Holy Moley! You've been knowingly riding around with pinholes in your carb diaphragms, and tried to diagnose other causes of stumble? Always one issue at a time as someone said above (I think Don).
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  I've been broke for the longest time if you go back through my threads....
                  This whole bike build has been on ECONOMY
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                    As a brethren if not a founding father of the CheapAzz tribe of XS owners, I have used RTV to seal over pinholes in the diaphragms before. Its not a long term fix, but it will buy you several months or more of service from the existing diaphragms.
                    And yes, that could easily be the cause of your stumbles. When you change throttle position is the biggest change in vacuum, and that is when the slides are trying to open and will flutter from the leaks in the diaphragms.
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      And the stumble has been on the backburner while I took care of all of the other issues, it runs, and gets me where im going ( when it decides to ) I'm just now beginning to focus on the little stuff
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        Originally posted by DGXSER
                        As a brethren of not a founding father of the CheapAzz tribe of XS owners, I have used RTV to seal over pinholes in the diaphragms before. Its not a long term fix, but it will buy you several months or more of service from the existing diaphragms.
                        I tried using that rubber sealant in a can...it didnt work too well.
                        I get the stumble at cruising or when just barely getting on the throttle...like just a HAIR above a closed throttle
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                          • 4015
                          As this is the first I've heard of the pinholes, the first fix on the otther forums was Plati-Dip, but did not hold-up over time. We now use Gorilla Glue in several layers, as it allows flex unlike the Plasti-Dip. One other alternative you could try is the gas sealer found at all hardware stores, auto parts stores, etc.
                            • 4015
                            Rubber Sealant? As-in Flex-All or Rustoleum variety? Yeah, they probs would not hold upto gas well. Some thought rubber cement would work; it did not.
                              I used the black RTV used for gaskets on engines. It held up for close to a year IIRC. I eventually spent the money a new slide with diaphragm.
