Brake/clutch Lever Bushings
  • MPittma100
    • Aug 2011
    • 2359
    Anyone have a source for the brake and clutch lever bushings?
    Mike
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Bearings
    I picked up a set of roller bearings from one of the guys on the 650 list. I'm sure if you have a bearing supply house you can most likely get the same thing.
    Requires drilling out the lever to fit the bearings the OD is the same the ID is not. If you can't find them I'd be glad to check the 650 list for who it was that had them. PM me. Done };~)
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
      • 2070
      Hi Mike, they are a nylon material.
      You may find your local hardware has an assortment you can fab a couple out of.
        Mike
        Hi Mike,
        those levers got bushings? I swear mine just got holes drilled through them.
        And yes, mine are worn all sloppy too.
        Get bushings at your nearest bearing shop.
        Ask for nylatron bushings.
        Or go old-fashioned and ask for oilite bushings which are made from lube-filled sintered bronze.
        Replace the pivot bolts at the same time, they will be worn too.
        • MPittma100
          • Aug 2011
          • 2359
          Bushings
          Hi Mike,
          Yes, they are nylon bushings. A bearing in there would be an upgrade for sure. If you don't keep the lever pivots lubricated, the bushings will disappear and the (handle) holes will enlarge.
          Mike
          K&N Air Filter
          ACCT
          EBC Front Rotors
          Mike
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            I like the idea of the bearing... if you guys post a link I would appreciate it (even if its to the XS650 site). Thanks.
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              Tip from the bodgers notebook.
              If you do have some levers with ovaled holes, and you can find some nylon bushings, a little JB Weld can be dribbled into the space around the bushing, and the lever is good to go another 100,000 miles. Clean the aluminum with acetone or equal to assure a bond to the inside of the hole.
              Be aware that JB Weld will droop until it sets up, so make sure that it can't drain out the bottom of the gap. A piece of Scotch tape across the bottom will usually keep it in, and any that does get into the inside of the bushing can be pared out with an Exacto knife, or a drill bit, carefully applied.
              CZ
                • 9980
                Much easier to find and cheap.
                Get the best deals for XS 1100 Yamaha Hand Levers at eBay.com. We have a great online selection at the lowest prices with Fast & Free shipping on many items!
                  • 7765
                  Those of us who are XS650 listers belong to an archaic email list. XS650.com is all about chopping our beloved motorcycles. OK, I exaggerate, but the site is full of Sawzall artists. Not a lot of quality content there. YMMV
                  • MPittma100
                    • Aug 2011
                    • 2359
                    New Discovery
                    Turns out that in the past I have bought a couple of spare (OEM) brake/clutch levers. The holes for the pivot bolt, of course, are the same size as the originals - requiring that bushing.
                    So I ordered an aftermarket one form EBay (item number 360791825509) and found out that the pivot hole is smaller - perfect size to fit the pivot bolt. No bushing required. Problem solved!
                    Mike
                    K&N Air Filter
                    ACCT
                    EBC Front Rotors
                    Mike
                      Mike
                      Hi Mike, that explains it!
                      I bought my XS650 new and when the original levers got broken in minor collisions I threw them away and replaced them with the aftermarket levers the dealer had in stock.
                      I never thought to check if the stockers had bushings in them.
                      All the other Yamahas I've owned were far from new and they must all have had aftermarket replacement levers by the time they got to me.
                      However, the good fix when they have worn sloppy and oval is to drill out the holes 8mm diameter and press in 6mm bore x 8mm OD nylatron or oilite bushings and cut them the same height as the lever thickness.
                      AND install new pivot bolts, the old ones will be worn too.
                      • donebysunday
                        • Oct 2012
                        • 1737
                        • New Berlin, Wi.
                        Been trying to get a lead on these roller bearings but no one on the list is answering me about them ?
                        76 XS650 C ROADSTER
                        80 XS 1100 SG
                          • 7765
                          That's because the 650 list is a bunch of old guys with CRS. We can't remember anything that far back.
                          • donebysunday
                            • Oct 2012
                            • 1737
                            • New Berlin, Wi.
                            Here's what I got so far on the roller bearings, Torrington B56 / B55
                            Another;
                            Timken engineers and manufactures bearings and mechanical power transmission products. We use our knowledge to help global industries operate more efficiently.
                            You will need to check the sizes.
                            76 XS650 C ROADSTER
                            80 XS 1100 SG
                              Hi Marty,
                              speak for yourself, eh? Remembering far back is no problem.
                              I can still remember my apprentice time-card number from 1957
                              (14151) and how to properly adjust a Velocette clutch.
                              As to what happened this week? Not so much.
