Bent intake valve #4 WHY ideas !
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    Originally posted by vedgar
    Gonna look for mid spec, shim if it is on the tight side. I dont have extra shims to shufffle around. Have a 79 SF with 26k on the clock and have not touched it (adjusted) in 2500 miles. Still sounds quiet.
    Vance
    Thats when you want to check them. The gap closes up (gets quieter) as time goes by.
    So If I were you, I'd check the clearances.
    CZ
      • 9981
      Vance
      P.S. Have a couple airhead BMWs', have to check them every oil change. Simple as pie to do them, not like the cover on my XSsssss' . I love all my 2 wheeled children.
      Set them to the widest spec. Properly adjusted it sounds like the engine is gonna fly apart but that's where it'll run best.
      • vedgar
        • 311
        • Clarkston, Michigan
        New valve delivered today
        Should have running by Friday .
        79 1100 SF Carmine Red stock
        85 Honda v65 Magna
        • GLoweVA
          • Jun 2011
          • 1957
          • Virginia Beach, VA.
          In case you didn't know, BMW shims are the exact same size as our XS11 shims, so you'll have more options when looking for shims.
          80G (Green paint(PO idea))
          The Green Monster
          Got him in '04.
          bald tire & borrowing parts
          Scarlet
          Got her in '11
          Ready for the twisties!
          81H (previously CPMaynard's)
          Hugo
          Cold weather ride
            Bent Exhaust Valve
            I had the exact same experince with one of my XS750s I purchased with 18k miles on it.
            Hadn't been run in years.....#2 Exhaust Valve bent slightly...no evidence of collision with piston or intake valve....cam timing correct.....
            Eventually I noticed some chewed up links in the cam chain, thankfully as I was still assembling it. I think in my case the cam chain might have worn loose from not being adjusted, then it slipped, and someone put it back. It's all I could guess after looking at the parts.
            In your case, we all don't imagine a loose chain at 2200 miles.
            We're all looking forward to hearing that it's running again. It's way too beautful to sit in the garage unused.
            • vedgar
              • 311
              Waiting for new Pilot jets
              Had running to make some preliminary checks. carbs back off for now
              85 Honda v65 Magna
                • 5073
                That is what I call PROGRESS!
                • vedgar
                  • 311
                  5 degrees F for tomorrow morning.
                  Between the bathroom remodel and Christmas stuff, have to put off Bike work for now. Updates when dialed in. Thanks
                  Vance
                  Colder than normal for this time of year in Michigan
                  85 Honda v65 Magna
                  • vedgar
                    • 311
                    Running great now
                    carbs dialed in .Took pics of timing marks as not to second guess myself if something did not seem right. I can look at the pics and at least verify the timing is spot on .
                    Vance
                    85 Honda v65 Magna
