Bent intake valve #4 WHY ideas !
Set them to the widest spec. Properly adjusted it sounds like the engine is gonna fly apart but that's where it'll run best.Gonna look for mid spec, shim if it is on the tight side. I dont have extra shims to shufffle around. Have a 79 SF with 26k on the clock and have not touched it (adjusted) in 2500 miles. Still sounds quiet.
Vance
P.S. Have a couple airhead BMWs', have to check them every oil change. Simple as pie to do them, not like the cover on my XSsssss' . I love all my 2 wheeled children.Greg
New valve delivered today
Should have running by Friday .79 1100 SF Carmine Red stock
85 Honda v65 Magna
First bike-s 2-1967 Yamaha YM2C Big Bear ScramblersComment
In case you didn't know, BMW shims are the exact same size as our XS11 shims, so you'll have more options when looking for shims.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
Bent Exhaust Valve
I had the exact same experince with one of my XS750s I purchased with 18k miles on it.
Hadn't been run in years.....#2 Exhaust Valve bent slightly...no evidence of collision with piston or intake valve....cam timing correct.....
Eventually I noticed some chewed up links in the cam chain, thankfully as I was still assembling it. I think in my case the cam chain might have worn loose from not being adjusted, then it slipped, and someone put it back. It's all I could guess after looking at the parts.
In your case, we all don't imagine a loose chain at 2200 miles.
We're all looking forward to hearing that it's running again. It's way too beautful to sit in the garage unused.-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
Waiting for new Pilot jets
Had running to make some preliminary checks. carbs back off for now79 1100 SF Carmine Red stock
85 Honda v65 Magna
5 degrees F for tomorrow morning.
Between the bathroom remodel and Christmas stuff, have to put off Bike work for now. Updates when dialed in. Thanks
Vance
Colder than normal for this time of year in Michigan79 1100 SF Carmine Red stock
85 Honda v65 Magna
Running great now
carbs dialed in .Took pics of timing marks as not to second guess myself if something did not seem right. I can look at the pics and at least verify the timing is spot on .
Vance79 1100 SF Carmine Red stock
85 Honda v65 Magna
