Re: Winter Storage Tips
  • CaptonZap
    • Jun 2010
    • 1748
    • Denver
    From http://www.hayabusa.org/forum/genera...ter-print.html
    Re: Xylene Fuel Additive / OCTANE BOOSTER
    Read on a site about the stuff...
    Number two thing: Add Acetone and Xylene to your fuel; gasoline or diesel. Acetone changes the surface tension of the fuel. That makes it spray a finer mist. That will make it combust better. Better combustion means leaner fuel and more efficient burning. But if your fuel contains 10% Ethanol, acetone will not help much. Big oil figured that out. Xylene will help increase octane and help override the affects of alcohol in the fuel. Together they work best; but the higher the Ethanol content, the less effect acetone will have.
    Number three thing: Add Mothballs made from Naphthalene. The old fashioned moth balls are 99.5 percent Naphthalene. The only kind to use. It takes an hour for them to dissolve, so you may want to crush them first. They will boost your mileage. Naphthalene is a hydrocarbon. Do not use more than 5 mothballs in 20 gallons. You don't want to carbonize your engine. Oh, and don't use mothballs if you are using Xylene. They do the same thing.
      • 4015
      I'm not a chemist, engineer, etc., but all I know is that I'd be very hesitant to stick anything in my gas tank besides gas. Any reason why people don't empty the tank completely and bring it in for the Winter?
        Hi Ian Mostly because we are lazy Full to keep air out and prevent corrosion or Empty and treat the insides to prevent corrosion.
        Full= Turn the key and go in the spring.
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Full
          Keeping the tank close to full and by turning the fuel valves on once a month during the storage keeps the moisture/condensation out of the tank and the carbs.
          Condensation means water/rust/corrosion.
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
            I have never used the stuff CZ is suggesting, not knocking it, just not something I have heard before or tried.
            As to why I add fuel stabilizer like Seafoam, because it deters the moisture formation in the fuel. I like to ride when I can through the colder months, we do get the odd warm day here and there throughout winter. So I do not pull the tank, or drain it. I do try to keep it close to full.
            I also have a SWMBO, so bringing a gas tank inside for safe keeping would be asking to give away half of everything I own, including said gas tank.
              • 4015
              So, I've decided that this may be the first year where I park the bike, fill it with gas, and have it turn-key ready for the Spring. I wanted to pull the engine and paint it, as well as the other colored pieces. I know my personality well, and I really don't want to miss out on that one nice day of riding. I think I can still swap out the coils for Honda VF coils, and work on bits and pieces here and there.
              • MarkD
                • Jun 2013
                • 488
                • N. Michigan
                2 more winterizing things I do: 1)fog the cylinders, and crank it over a few seconds with the plugs out. 2) Hook up the battery to my battery minder.
                79 F
                1967 Suzuki X6 Hustler
                1973 Suzuki TM 125
                1979 XS1100 F
                2005 Kaw. Vulcan VN800
                1991 BMW K75
                • mikubuilder
                  • Jul 2011
                  • 548
                  • Westland, Mich.
                  I got my tank lined, so last year I drained it dry, same for carbs....I think I might brake down this year and buy petcock towers, plus I have a slow leak from one of petcock screws(missing fiber washer)....so I'm gonna drain the tank this year, too.
                  Battery tender is a must, especially if you have older style battery...
                  Nick
                  1982 Virago 750 (it's alive!)
                    You are better off if you bring the battery inside. I have heard that simply disconnecting the negative lead after a full charge is a good alternative. I keep them garaged and start them occasionally running with a throttle lock at 3000rpms to charge and long enough to make the pipes good and hot. My neighbors hate me I am sure!
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      How do you get all the fuel out of the tank and carbs/lines ? If you have ethanol fuel the little bit left after you drain it could cause problems but if it works for you ?
                      As far as the washers for the petcock screws, I have access to discontinued leather furniture samples. With different sized punches I cut out little washers, super glued them together ( swede side to suede side) and made my own petcock washers.
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                      • MarkD
                        • Jun 2013
                        • 488
                        • N. Michigan
                        Up here in the North, ( I know, it's South for some of you guys) there are a few times my garage will get below freeze temps, so I bring in the trolling motor battery and the XS battery. To get them to last more than 2-3 years, you have to baby the things.
                        79 F
                        1973 Suzuki TM 125
                        1979 XS1100 F
                        1991 BMW K75
                        • puskrat
                          • Jun 2015
                          • 312
                          • Peoria IL
                          Mac,
                          The farther you are from the big city the less likely to have ethanol in your fuel.
                          Just heard the the EPA may release it's hold on the states to use ethanol gas.
                          It's hurts more than it helps the environment (air we breath), it adds to the cost of fuel production and in engines it is damaging.
                          fixed it for ya
                          reduces fuel economy as well. one of the components of "hurting"
                          "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
                          Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
                          • Bikes
                            • Oct 2014
                            • 174
                            • Coastal Maine
                            I run my bikes all winter, good warm ups and rides if the roads permit.....i also wind up stealing gas from the bikes to use in the generator or snowblower, then I refill next time I go out......they get fresh gas a few times during the winter..
                            I do use stabil too or seafoam, and the reverse in the summer...its an endless cycle......no pun intended....
                            Mark
                            1980 xs1100g 3H5.......
                            1992 Ducati 907ie
                            2001 Moto Guzzi Jackal
                            • Bikes
                              • Oct 2014
                              • 174
                              • Coastal Maine
                              In non running bikes, I usually drain the float bowls and tank and then spray the insides of the float bowls and tank with wd 40....if you use then red tube, its easy..
                              Mark
                              1992 Ducati 907ie
                                So, after reading the article, I got to thinking: where is the harm in parking the bike, but running it a couple times a week, instead of adding Sta-bil, etc.? We all know we get that one day in the middle of Winter where temps hit a high, and the snow melts, and we want to go for a ride.
                                Use of Startron is your best bet. It keeps fuel compatabile with the alcohol. Otherwisw fuel/alcohol seperation occurs, which IS where inlies the carb problems with sticking moving parts(BTDT). Seafoam is to be used in fuel as a cleaning agent, not a fuel stabilizer. Lots and lots of experience using both, but Startron IS what is to be used for extended storage or with the occassional start-up of motor. Just be sure and run motor initially so the mixture occupies carbies. Startron USED to only available at motorcycle shops, but now is readily available at any parts store and even some of the WallyWorld stores.
