Which Emulsion Tube?
  • MPittma100
    • Aug 2011
    • 2359
    As I tear down a set of 1979SF carbs, I find two emulsion tubes with 4 sets of 4 holes and the other two have alternate hole sets of 3 and 2.
    Are these the correct tubes? If so, which locations are they supposed to be. When coming apart, the two 4 hole tubes were on cyls. 3 & 4. The 3-2 hole tubes were on cyls. 1 & 2. Does not seem right.
    Thanks, MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
    Thanks, MP
    If there correct, two for center two cyl. and other two for outer two cyl. Which is where?.......havent a clue associated with the early carbs.
      • 8962
      The holes are air bleed holes, the tubes with the least holes (richer) go in carbs 2 and 3 to provide a slightly richer mixture for better cooling on the two center cylinders.
      • MPittma100
        • Aug 2011
        • 2359
        Good to Know
        Thanks Motoman and Phil. They were not in the correct place but they will be.
        Mike
        K&N Air Filter
        ACCT
        EBC Front Rotors
        Mike
          • 5073
          Phil hit the nail on the head.
          • MPittma100
            • Aug 2011
            • 2359
            Nail
            As usual. We like it that way. That information is not in the book.
            MP
            K&N Air Filter
            ACCT
            EBC Front Rotors
            Mike
              • 8962
              Pretty sure that Standard carbs (early style) have the same 4 tubes across, only the Special had the mix. BTW, the mains were always the same size across on the board on all early type carbs.
