Where Does This Part Go?
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Hello All
    I was wondering if you can help me identify this part. I can't seem to find it on the microfiche. At one time i thought it was the rear brake bracket but that is not correct.
    Also, I have the round exhaust gaskets but I was wondering if there is supposed to be something else between the pipes and the engine? Is there supposed to be a copper washer or something other than the "Paper" gasket? Thanks
    Jared
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
    It is the torque bracket on the rear brake of a special. Will not work on a standard.
    Nothing else needed for the exhaust gaskets.
      Hey Rev/Jared,
      "Paper" exhaust gaskets??
      Do they look like this?
      These are what the exhaust gaskets should look like, they have non-stick covers on them that you peel off and then you can stick it inside the head port. It will stick to the head instead of falling out while you put the headers on. They are metal and designed to crush and seal as the headers are tightened against the head. The old ones can look almost like the actual head material inside the exhaust port. I've meant to take and post some photos of an old head with them in there, and then after they were removed, because they fooled me the first time!
      • Tat2demon
        • Jun 2012
        • 718
        • Sioux Falls, South Dakota
        Wish I had realized that when I replaced mine! I slathered them with silicone grease to make up stay put.
        Hey Rev/Jared,
        Nate
        78 XS11 "Matilda" 2H7 000364
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
          Well....I missed the "paper" part! No they shouldn't be paper! As TC said, they are metal!
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            Those have adhesive on them?!!?!?!?!?
            RAWRRRRRRRRRRRRRRRRRRR I wish I knew, It took me FOREVER to get those things in there without falling out
            79F
            "Excelsior"
            Honda gl1100 handlebar
            Vetter IV fairing with speaker system
            OE headers,Jardine slipons
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            Oe hardbags and luggage rack
            TC fuse block
            K&n filter with oe airbox
            Raptor 660 Acct
              • 9981
              A little silicon or weather strip adhesive is OK to use to hold them in place. I've just squeezed them so they are slightly out of round so they will stay in also.
                A bit of anti seize works as well to hold them in place and then, in theory, help them come out later.
                  • 5073
                  That is exactly what I did. Great minds think alike.
                    Should of used a film of HighTempGrey silicone. That'll hold them in place and give them an additional seal that WON'T burn out.
                      For me, the general technique is to get the headers up against the exhaust ports with the pipe on the bottom lip, then carefully drop the gaskets in from the top and try to hold them there in place while I smash my finger several times.
                      You lazy people and your shortcuts..
                        • 9981
                        Doh OUCH!.......doh OUCH!......doh OUCH!.
                          Hey Tat/Nate and Sparkfly,
                          Nobody called me on this, but I may have been WRONG in what I wrote about these gaskets!? I don't know if it's C.R.S. or what, but I "thought" they had an adhesive on their sides....I remember the sides having paper, but I may have been mistaken regarding the presence of an adhesive layer!? And it's been a few years since I've played with them.
                          As has been stated by the others, a thin layer of silicone adhesive of your choice will help them stay in place in the head.
                          My sincere apologies to the masses for my faux paux.
                            • 9981
                            Just glad I'm not the ONLY one......
                            • James England
                              • 3039
                              • North of England
                              No, it's actually not adhesive. Sorry to spoil what sounds like a great idea. It's a felt-like papery stuff but definitely not sticky and not a pull off strip to expose adhesive underneath.
                              I prefer this sort of header gasket to the copper ones. I'm not quite sure why I do... Think it's because the copper ones take more torque to squash them and are not as wide. I've used a lot of these gaskets and I usually hold them in place with a blob of grease, anti-seize or, more recently, high temp silicone......
