Stock Muffler Patch?
    • 4015
    I have a pinhole leak on my muffler. What can I use to patch it? JB Weld? Ideas?
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Depends on how hot it gets. I used it to patch the oil screens in the bottom of XS650s, had a temp dip stick so I know it will stand up to oil and 250°+. Checked it at 5K and 10K, good. Funny, many said it would melt. I figure if the oil gets hot enough to melt JB Weld you have most likely holed your piston/s. Oh, I also used it to put a cylinder fin back on, held fast.
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
      JB weld will NOT stay on the chrome. It'll pop off when it's hot.
      Before replacing my left-side exhaust with a COMPLETE new OEM left side which included the already inserted gaskets, clamps and heat shield, just wire-feed spot welded the pinholes. Unseen, as they all were on the underside, and the short heat time spot welding kept heat from damaging the chrome around the spot welds.
      1500degrees to breakdown chrome happened quickly with just the spot welds, so any grinding prior isn't necessary. Hit the spots with Duplicolors Hi-Temp silver to avoid any rust. BTW, that particular paint does NOT change color from heat, not even at the head pipe collector.
        • 4015
        Interesting. Thanks Motoman.
          Most welcome, hope that was of some help for a temp. fix!
            There is a small hole around the footpeg that is there more moisture to exit if it builds up in there
              • 4015
              Hmm. I don't think this is that. Definitely a hole.
