Rear Brake Spring
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Rear Brake Spring
    Hello
    I have been rebuilding my 79 Standard and I am having the worst time trying to figure out the Rear Brake Lever Spring. I have looked at the microfiche for my model but it dosen't help one bit. I can't seem to install this thing so there is tension on the lever. In other words, it dosen't spring back like it should. The spring must connect onto the frame somehow but i can't seem to get it to work. Can someone post a picture for reference.
    Thanks
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
  • FJ111200
    • Oct 2007
    • 317
    • Crewe, Cheshire, UK
    The first picture shows the spring wrapped around the pivot and you can see the hook on the spring over the mechanism.
    The second shows the long tang hooked under the rear footrest bracket.
    It's abit of a fiddle to get right at first but once you've done it you'll get the hang of it.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      Thank you very much. That helps greatly.
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Bolt Kit
      Maier Fairing
      Spin On Oil Filter
      Plasti Dip Rims
      ISO Grips
      • boofer
        • May 2013
        • 25
        • Orlando, Fla.
        Could someone repost the pics as they seem to be missing. I am having exactly the same issue (senior moment)
        '79F - Bought it new
        '75 Honda CB400F - First street bike
        '09 FJR1300 - Long distance machine
        '11 Diavel - Mid life crisis
        '12 Multistrada - Hooligan Bike
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          This good ?
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
          • boofer
            • May 2013
            • 25
            • Orlando, Fla.
            Thanks much, that helped as did this post ! I dinked around with it and after some quality reflective time......figured it out.
