Wiring Help
  • Filter
  • #16
    Hi TC
    I haven't gotten the bike out yet because I still have 2 feet of snow. I will test it out ASAP. However, I like Ted's suggestion. It seems simple enough. My plan was to use the negative lead off of one of our coils first and see what it reads. Although with a wasted spark ignition I am not sure which wire is the negative lead, or if we even have a negative lead. I was going to use a process of elimination to find the correct one. Anyhow, I spoke to a guy that has a kz1100 and that's what he did. It originally read high so he put a 10K ohm resistor inline on the tach wire to get the signal down. He says it works great. It's worth a shot. If it works then it might become a popular mod. I am also working on my LED headlight mod.
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
    • #17
      Hey Rev,
      On the OEM bike, the negative side of the Primary wires of the coils are the Orange and Grey wires of the pair....the Red/White ones are the (+) ones. With my aftermarket Dynatek coils, they don't have a (+) or (-) terminal, but the OEM wires are still the same, so I will still be able to use the Grey/Orange wires as well. I don't know what wire your friend with the KZ used, but it shouldn't need a 10K ohm resistor?? I hope he hasn't tapped in the PLUG WIRE??
      • #18
        TC
        I think you can just attach a new tac wire up to the post on the coil. I don't think you need to splice into the orange wire. Or am I wrong?
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
        • #19
          Hey Rev,
          Yes, you're right, I was just using the COLORs to tell what were the Negative vs. the Positive ones. Yes, my wires are now bolt/nut attached at the coils so I won't need to actually cut/splice into the wires.
