OEM Exhaust Footpeg vibration
    • 4015
    So, any solutions to diminish the footpeg buzz I feel from the exhaust? Don't believev I am missing any bits to the exhaust. I figured on putting some foam/rubber here and there, but I'll solicit some ideas.
    Do you have the rubber isolator in place?
    See part #31 in this diagram
    Otherwise, you could add a rubber washer between the exhaust bracket and the footpeg bracket.
      • 4015
      Honestly, it was hard to make sense of that parts diagram.
        Hi Ian,
        hit the + until it get big enough to see then look for 31
        It is the rubber "doughnut" that goes in the cast aluminum part to hold the exhaust mounting bolt.
          • 4015
          Ahh, thanks Don & Phil. Yes, the insulator is still on both sides. I believe the mufflers are literally touching the frame right underneath the footpegs, and that's what I feel. I'll put something between them and see if that helps. It's such an irritating massage, lol.
            The way it is supposed to work is that part 31, is the rubber isolator, the bolt goes through the sleeve part #32 that is inserted into the rubber isolator. But yes, in the end you do have metal to metal contact at the bracket against sleeve 32 and it against the peg bracket. I would suggest a good thick rubber washer between the exhaust bracket and the peg bracket or the sleeve.
              Hi Ian,
              The exhaust should not touch the frame. Only the mounting bracket to rubbermounted bolt.
