Weird Running Issue
    Weird Running Issue
    I have a strange issue that I can't quite figure out. Startup and idle are all fine, I can rev it fine in neutral, but once I put it in gear it feels like I am down at least one cylinder. It almost behaves like a pickup issue BUT IT IS NOT THE PICKUPS (I emphasize this because you are all going to tell me this is the issue and it is not).
    I put it up on the center stand today and fired her up and as it was idling I started manually moving the pickups and advance and it didn't cause any problems. When I put it in gear though it it started acting up. It almost sounds like some sort of transmission issue. It sounded very "chunky" and jerky.
    I don't know where to go with this or how to describe it (I am bad at describing things like this)
    Nate, with it in gear, if you ad fuel does it help or bog down worse? It sounds like possibly a weak coil to me.
      It stays about the same. It can still pull itself along. I did ride to work one day with it like this.
      Coils have crossed my mind. I do have the POS mike's green coils...
      • Gallaecus
        • May 2011
        • 254
        • East Haven Connecticut
        maybe i am wrong, but if you put it in gear on the center stand, the dogs in the slots will constantly bounce back and forth. with no resistance to the back tire, such as pavement, i think it would be normal for the trans to be clunking around and probably not good for it.
        Steven
        1981 XS 1100 LH
        1979 XS 1100 SF
          Have you checked your pickup coils??
          OK, now that you're mad.. lol. Have you checked your plugs/wires lately? A bad spot or bad plug will let it idle, but jump to ground as the amps go up.
          A lot of times, putting the bike in gear on the center stand, the drivetrain will get clunky since there's no pressure on gears. Slightly add some back brake while it does this to see if that stops the clunking.
          Oh... and do you have another TCI you could plug in to check if it's that?
          That's all I got at the moment, but also.. don't forget to check those pickup coils!
          PS.. And Gallaecus beat me to that part.. lol
            I still gotta stay with the pickup wires Nate. It sounds like one is shorted to the neutral switch wire.
            Try disconnecting the neutral wire from the switch and grounding it so the green light is on all the time and see if it eliminates the misfire in gear.
              I will recheck with the rear brake lightly applied.
              Neutral wire has been grounded out for months now.
                Slacker... lol.
                  Originally posted by trbig
                  Slacker... lol.
                  I think we may have found the problem.
                  WTF does the rear brake light have to do with the price of rice in china?
                    Take another pain pill and down a beer, Greg.. then go back and actually READ. "Brake lightLY"
                      Oh, I see. My trans rattles at low RPM also particularly when it's running rough. It's the normal slack in the gears.
                        Slacker... lol.
                        Piss off, both of you
                        But now I am out of gas...guess I have to go out then today.
                          Being real low on fuel can make it run funky too Nate.
                            No, that is not the issue.
                              • 4015
                              Hey Nate- Do you have this issue when it rains? I think the guys on here attributed my issues to a possible coil issue, as it revs fine in neutral, put her in gear and go, and it bogs down. I never bothered to check on it.
