Center Stand
  • senrak
    • Jun 2012
    • 70
    • Rhinelander, WI.
    Center Stand
    Finally getting the XJ near completion. When I bought this bike it had no center stand.I found one (I forget were), cleaned up and installed it. Put it up on the center stand for the first time today and found something amiss. I know that one of you guys know the answer to this.
    The stand rolls over center to far, taking it off the left foot and onto the foot pedal. Do I have the wrong stand? Are there different ones though the years?
    I know one of you knows the answer.
    <a href="http://s470.photobucket.com/user/eladsenrak/media/PICT0052_zps0df5b1ae.jpg.html" target="_blank"><img src="http://i470.photobucket.com/albums/rr63/eladsenrak/PICT0052_zps0df5b1ae.jpg" border="0" alt=" photo PICT0052_zps0df5b1ae.jpg"/></a>
    82 XJ
    The travel limiter on the frame/stand might be bent.
    • senrak
      • Jun 2012
      • 70
      • Rhinelander, WI.
      There is no evidence of the limiter being bent.
      82 XJ
        Hey Senrak,
        I remember someone posting about how the Specials and Standards were different because of the size of the rear wheel.
        I checked a few on the parts fiche, the 79F is different than the 81SH and the 82XJ..both of those are listed as the same. However, the part #'s for the 81 series is the same for standard and special?
        2H7-27111-00-00 79 F
        3H3-27111-01-00 81 H
        3H3-27111-01-00 81SH
        3H3-27111-01-00 XJ11
        • senrak
          • Jun 2012
          • 70
          • Rhinelander, WI.
          Thanks T.C.,
          So it is possible that I have the wrong stand mounted on my 82 XJ.
          Rather than search for another, I think that I can weld some pads on the stand and make it hit the stops a little sooner.
          82 XJ
          • Petersg_99
            • Apr 2012
            • 184
            • Phoenix, AZ.
            Wow, a grey frame seems like a bold choice. You worried about keeping it clean?
            Guy
            1980 XS1100G - Frankenstein - resurrected from the impound lot
            1991 Suzuki GS500E (not running yet)
            2003 Burgman AN400 - Blue Belle
            2005 Burgman AN400 - Silver Belle
            • senrak
              • Jun 2012
              • 70
              • Rhinelander, WI.
              It'll never see dirt if I can help it!
              82 XJ
                Originally posted by senrak
                Thanks T.C.,
                You've got the right stand (I can tell by the style of 'pedal arm' on it), so there's three possibilities as to why it's doing what it is....
                1. Worn/damaged frame stops.
                2. Bent pedal arm
                3. Wrong bolts holding it on.
                These are held on with special 'shoulder bolts', and if what you have in there is smaller, it will allow the stand to rotate too far forward. Even with the right hardware, the pedal ends up almost touching the floor.
                • senrak
                  • Jun 2012
                  • 70
                  • Rhinelander, WI.
                  Thanks for the replies. You guys always come though.
                  I got the shoulder bolts and spring with the stand and they are installed. The pedal does not appear to be bent. The frame mounting points must be the culprit. Although I did not notice that they were deformed, I did need to weld a crack in that area. So maybe they were bent.
                  I solved the problem by welding 3/16 of an inch on the top of the stand were it contacts the stop. Problem solved. Works fine.
                  Thanks again,
                  DW
                  82 XJ
