I replaced the head gasket on the '79 I picked up a couple month ago as part of it's restoration. Now it's leaking out of the back side of cylinder #1 or #2 and I want to retorque down the head. Obviously when I replaced the head gasket the first time part of the process is remove the cams, etc. but I am wondering if there's anything wrong with skipping that step and just taking off the cam nuts, lubing them like it indicates in the manual and putting them back down to get better readings on my torque wrench (so it's not the torque + the resistance on the threads). I won't be moving the heads at all just properly loosening the nuts (in order of course and in a two step process like it says), lubing them with high temp lubricant (graphite or whatever I find at the store), and tightening them back in the appropriate order.
I would love to be able to skip the steps of removing the cams again if at all possible.
. I don't think the gasket was bad since it was the one I got from you but who knows? I think the more likely culprit is that the head nuts are putting up a fight and therefore my torque numbers are off. Ideally, what I should have done if I wasn't so stubborn is when I had the heads off taking a die to the threads of the head/cylinder bolts and replacing/retapping the head nuts to ensure that they would go back together nicely.
(and 4 as well)
