No reason ever to remove the snorkel or bracket. That airbox WILL pull back and down against top of engine case to remove carb bank out the left side. Sorry, just don't get all this unnecessary modifications in order to remove carb bank. If I have the lowers on fairing, still only takes less than 15min. so have carb bank on bench.
stuck float again
Maybe it IS different on the Standards then, all I have ever owned and really worked on were Special models. On the Specials, the lower section of airbox is of course removed, but the top section will only slide back about 1/2" to an 1" before it hits the battery box. The bracket on top, over the frame, and the snorkel over the battery area keep the upper section from dropping down. So you need to pull the carbs back, then twist them front to back to get the inlet bells above the air intake stacks, so you can now elevate the carbs above the boots. then the carbs will slide out, ever so carefully, as you work the idle adjustment section around the oil tube.
By doing the above modifications, the upper air box section can drop down out of the way to sit almost on op of the middle drive. This creates a lot more space to pull the carbs back out of the intake boots and remove them from their space.
It can be done without the mod, done it many times. But with those two mods it is ALOT easier.Life is what happens while your planning everything else!
78 XS750Comment
I cut that bracket off long ago and haven't thought a bit about it since. Couple weeks ago I went to help someone with his carbs and he has a MNS and I have to say that stupid bracket was in the way, not really a problem but it slowed things down a bit.Nathan
Theodore RooseveltComment
I'm leaning towards DGXSER on the 1" of clearance thing. If I remove battery, the box can go back further. However, after having just done this last week with battery in, it still was easy as pie for me. I do have to stipulate one thing that MAY make a difference and steer people in the wrong direction as to the ease of this, I DO NOT HAVE A LOWER HALF TO MY AIRBOX.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Either way though you remove the lower half of the airbox first.Nathan
Nate- No, I have Shousey440's automotive airbox conversion
It can be done without the mod, done it many times. But with those two mods it is ALOT easier.Marty (in Mississippi)
XS650EComment
On my way to XS SE, I had to pull them off.
It was easy, but a PITA because the engine was HOT.
Reaching under there to loosen the airbox screws sucked!
I also had a shorter screwdriver than I would have liked, but I still got it done pretty quick.
I have the bicycle seat conversion on my SG seat, so pulling the seat was a snap and the 2 bolts on the side of the airbox and the 8 clamps then slide the bank out the left side.
I still have the full bracket up top, but I don't put a bolt in it.
It does hinder the re-aligning of the airbox boots to the carbs some, but with a little finesse, it'll go on okay.
I may replace the phillips screws on the clamps with something like allen cap screws instead. Trying to line up the screwdriver with those little screw heads on #2 & 3 are a little tricky too.
I didn't think that my little report of my 2 time failure/repair would generate this much response, but that's one of the things I like about this site (and people) is the sharing of ideas and opinions. It makes you think about how you do things and maybe there may be a way to improve upon the process.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
XS650EComment
I like to push the air box down about 2-3" and then pull the carbs back then slide out to the left. The oil feeder tube interferes with the idle adjustment knob, that's why I pull the rack backwards a little.
Plus, by pulling the airbox lower (and air filter) I can check it out for fuel overflow. (which I had in both cases this time)Hi, my name is George & I'm a twisty addict!
The Green Monster
Got him in '04.
Scarlet
Got her in '11
Hugo
i've found that without taking the bottom of the airbox off, there's not enough room underneath for the air box to drop (due to breather hose and fuel lines) this allows the inlet carb bells to clear the inlet tubes.
I like to push the air box down about 2-3" and then pull the carbs back then slide out to the left. The oil feeder tube interferes with the idle adjustment knob, that's why i pull the rack backwards a little.
Plus, by pulling the airbox lower (and air filter) i can check it out for fuel overflow. (which i had in both cases this time)81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
