Idle adjustment screw.
  • Idle adjustment screw.
    Hey fellas, Trike is coming along nicely. Just took it for a test ride yesterday up and down my street and all seems good so far.
    Take a look at the second pic of my idle adjustment screw, it's almost impossible to get to it with a screw driver to make adjustments. I even tried a little stubby screw driver but I cant even get my hand in there. Is this the normal location for the screw? I sent the carbs out to have them rebuilt and I don't remember if that's hoe it was originally set up. Is there a way to relocate it to the top?
    Thanks.
    That is where it is supposed to be but the screw is not the right one. The original screw is a bigger one with knotches on the outside edge of the screw so that you can turn it by hand or push sideways with a screwdriver to adjust it.
      ........odd.....
      Mine points up between #2 & 3 carb, and I thought that was normal...
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
        Originally posted by sparkfly88 View Post
        ........odd.....
        Early carbs point up on the airbox side. Late carbs point down on the engine side.
          Thanks. I guess I'll just have to find the right screw. Anyone have one for sale?
            trike
            What did you use for a rear differential? XS output rotates backwards from automobile.
            put something smooooth betwen your legs, XS eleven
            79 F (Blueballs)
            79 SF (Redbutt)
            81 LH (organ donor)
            79 XS 650S (gone to MC heaven)
            76 CB 750 (gone to MC heaven)
            rover has spoken
              The rear end is out of a fox body mustang. It's flipped due to the rotation of the motor. I modified the rear end so it would have proper oil circulation. Now I know some people are going to say that a rear end wasn't made to run in reverse, it won't last long. Thats crap, its done all the time in off road trucks where they take a heavy dury rear end and flip it, install steering joints and put it up front. As long as the oil circulation is correct there will be no problems.
