Idle adjustment screw.
  • Sacred Steel
    • Mar 2012
    • 6
    • Easton, Mass.
    Hey fellas, Trike is coming along nicely. Just took it for a test ride yesterday up and down my street and all seems good so far.
    Take a look at the second pic of my idle adjustment screw, it's almost impossible to get to it with a screw driver to make adjustments. I even tried a little stubby screw driver but I cant even get my hand in there. Is this the normal location for the screw? I sent the carbs out to have them rebuilt and I don't remember if that's hoe it was originally set up. Is there a way to relocate it to the top?
    Thanks.
    That is where it is supposed to be but the screw is not the right one. The original screw is a bigger one with knotches on the outside edge of the screw so that you can turn it by hand or push sideways with a screwdriver to adjust it.
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      ........odd.....
      Mine points up between #2 & 3 carb, and I thought that was normal...
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
        Originally posted by sparkfly88
        ........odd.....
        Early carbs point up on the airbox side. Late carbs point down on the engine side.
        • Sacred Steel
          • Mar 2012
          • 6
          • Easton, Mass.
          Thanks. I guess I'll just have to find the right screw. Anyone have one for sale?
          • rover
            • Jan 2004
            • 765
            • central WI (715)
            trike
            What did you use for a rear differential? XS output rotates backwards from automobile.
            79 F (Blueballs)
            79 SF (Redbutt)
            81 LH (organ donor)
            76 CB 750 (gone to MC heaven)
            rover has spoken
            • Sacred Steel
              • Mar 2012
              • 6
              • Easton, Mass.
              The rear end is out of a fox body mustang. It's flipped due to the rotation of the motor. I modified the rear end so it would have proper oil circulation. Now I know some people are going to say that a rear end wasn't made to run in reverse, it won't last long. Thats crap, its done all the time in off road trucks where they take a heavy dury rear end and flip it, install steering joints and put it up front. As long as the oil circulation is correct there will be no problems.
