Oil pan drain plug
    • 9980
    I didn't realize the XJ frame was that different.
    Must have been hell fixing XJOK2PLAY's oil pump in a parking lot.
      We didn't fix it until we got it home. COULD have.. just thought more things were tore up than there were.
      MUCH more fun tearing the back end and middle drive out of a bike in a truck stop.
        • 9980
        Your not going to do that again this year are you?
        I was going to say earlier that you could just go on ahead and we'll catch up after you disassemble and reassemble your bike and we'll just get a hotel where ever that happens like last year.
          Back on subject...
          I pulled one of those hollow bolts mentioned from another motor, then grabbed another pan and checked. That bolt will go way into the 2nd set of threads on that pan. Looks like it's going to work, but I'll miss my magnetic plug. Oh well.. I've got a magnet in the oil pan as well.
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            Originally posted by trbig
            Back on subject...
            If i remember the little guy is reverse threaded?
            79F
            "Excelsior"
            Honda gl1100 handlebar
            Vetter IV fairing with speaker system
            OE headers,Jardine slipons
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            Oe hardbags and luggage rack
            TC fuse block
            K&n filter with oe airbox
            Raptor 660 Acct
              You remember incorrectly.. lol. And it's not a little guy. Pretty decent sized bolt.
              As I said, I grabbed another pan and gave it a try.
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                The center insert wasnt reversed??
                The ones I used to mess with were I thought, that way you wouldnt loosen the rethreaded section
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  The center insert is kind of corkscrew grooved, but not sure why since the inside of the bolt is smooth-walled.
                  But the bolt itself is standard threaded to the right.
                    • 9980
                    I think the grooves are for oil to get in there. I bet you could find a little round magnet an epoxy it in there.
                      Ehh.. Like I said. There's one in the pan already and this is just a temporary fix anyway.
                      • donebysunday
                        • Oct 2012
                        • 1737
                        • New Berlin, Wi.
                        So you have a magnet JB Welded to the bottom of your oil pan ?
                        My SH does not have a magnetic drain plug, I'm used to having these on the XS650s and would really like to have one on the SH11.
                        Make my own ?
                        I've picked up many different magnets along the way, some little tiny ones that are really powerful.
                        76 XS650 C ROADSTER
                        80 XS650 G Special II
                        https://ibb.co/album/icbGgF
                        80 XS 1100 SG
                        81 XS 1100LH/SH DARKHORSE
                        https://tinyurl.com/k6nzvtw
                        AKA; Don'e, UD, Unca Don'e
                          Make my own ?
                          Or go buy one for a couple bucks at the oreileys down the road from you
                            It's a magnet out of a microwave. Thin/flat and looks like donut. And no, no JB weld. It's just stuck to the bottom of the pan.
                              How would it stick to the pan? The pan is non magnetic aluminum.
                                Well crap.. Thanks a lot Nate. Now I'm sitting here wondering if I did drop that in the pan.. thinking it would be perfect in there.. nice and flat, powerful... or if I just thought a lot about doing it.
                                I've got one a lot like it in behind the oil filter cup of my dirt bike. Same kind of setup sort of as ours, but smaller. Filter inside a cup. It's stuck to the filter metal.
                                One way to find out, see if another magnet sticks to the pan, eh? Surely I wouldn't have let one just flop around in there? Crap... Now I'll have to check tomorrow. But thinking now that's why I got the magnetic plug?
