Tire pressure & mileage question
  • Poprock
    • Apr 2005
    • 594
    • Oregon Coast
    I run Shinkos. 40 front, 42 rear. Handles light, rides smoother than with other tires, (Dunlop, Metzelers) at the same presssure. MPG varies, but 33-36 local and up to 38-39 highway. I have to drive 70 miles to legally go over 55, so must of my driving is at that speed or slower. Longer trips make better mileage than short hops to the store and back.
    Oh, and I use dino oil.
    • tcoop
      • Nov 2009
      • 793
      • South Weber, UT
      On my resent trip to the Co Rally I ran 30 psi (gauge measured incorrectly set to 40 psi shortly after arriving) in front and rear with that I averaged 47 MPG On the way there
      On the way home I averaged 45 MPG with the 40 PSI.
      Part of the equation is it seemed to be more down hill from Ogden to Grand Junction. So I may have gotten better gas mileage on the way to the rally if the tires were properly inflated.
      Ty
      78 XS1100E - Now in Minnesota
      80 XS1100LG - The Punisher
      82 XJ1100 - Daughter's Bike
      • MPittma100
        • Aug 2011
        • 2359
        Mpg
        Always have run 40 psi front & rear. Mountain riding 38-40 MPG. Highway 42-44 MPG. Have gotten 50 mpg in Florida at sea level. Bike is fully loaded Venturer.
        May try higher psi?
        1981 XS1100H Venturer
        K&N Air Filter
        ACCT
        Custom Paint by Deitz
        Geezer Rectifier/Regulator
        Stebel Nautilus Horn
        EBC Front Rotors
        Limie Accent Moves On In 2015
        Mike
          May try higher psi?
          You aren't twisting the throttle hard enough!
            May try higher psi?
            Mstly mountain type riding/higher elevations in my area, with similar mountain riding mileages.
            • Geezer
              • May 2003
              • 2985
              • Willamina, Oregon 97229
              I was told by a tire company rep to always run the max treasure listed on the side of the tire. Bike tires somewhere along the way were changed from bias ply to semi radial design and the semi redial tires need more pressure than listed in the manual for the bike.
              Geezer
              • speedlimit85
                • Jan 2017
                • 491
                • Gainesville, Fl.
                My bike frame says 32 front 40 rear.
                80 G
                  • 2104
                  My '80G full dresser has scary slow speed steering if the front tire is under 40 psi. , feels like it's in mud. Running new Conti-Go front & rear and the front tread direction is reversed or opposite the rear tread. Not sure about mpg's but my spm's (smiles per mile) are great.
                    +1 on the Conti-Go tires......42psi front/rear.
                      Geezer
                      Hi Geezer,
                      I always go for the Max Treasure too
                      I also run 40 psi front & rear
                      • Geezer
                        • May 2003
                        • 2985
                        I was a real stick in the mud about using only the factory specs for tire pressure until I had a chance to talk to someone that actually knew why tires should be inflated to max pressure listed on the tire...
                        • speedlimit85
                          • Jan 2017
                          • 491
                          • Gainesville, Fl.
                          I just got a new rear tire...Conti Go.
                          80 G
