exhaust bluing.
  • graybird78
    • Apr 2003
    • 360
    • council bluffs iowa
    exhaust bluing.
    so the jardine exhaust is blue. it was that way when i got it.whats the best way to get rid of the blue coloring. do have some blue away.
    when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
    graybird78
    80 sg (old faithfull)
    Keep rubbing using tiny amounts of Blu-Away. Problem is, bluing will be back as the chrome quality is not the same as original pipes, plus, they were double-walled. With that said, trying to keep the bluing off thos pipes WILL deteriorate the chrome finish quicker...JAT to consider.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      The blue is going to be there unless you remove the metal that has turned blue. This is not good as it removes metal that protects the pipes, so rusting becomes a problem. Best to enjoy the blue as a hot race bike look and use Flitz to keep them as polished as posible. I've seen demonstrations at gun shows where the Flitz takes off finger prints and such to present a show blue job finish but if left with no oil on the gun over time it will rust. Unfortunately you can't oil your pipes so repeated cleaning is the only way to try and hold off the elements that will cause rusting.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • graybird78
        • Apr 2003
        • 360
        well now, that doesnt sound very promising.
        graybird78
          • 8708
          I got tired of bluing and/or gold chrome, I just scuffed the chrome headers and shot it with hi-temp black. Just a suggestion.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            There is high temp chrome spray, but ceramic is the cure, cost is the hard sell !
            76 XS650 C ROADSTER
            80 XS 1100 SG
              There are several coatings that can be applied to the interior of the pipes to help with bluing, but you need new, clean pipe for it to bond. If you can sandblast the inside clean, they may be worth a try.
              • Rasputin
                • 3187
                • Lacombe, Alberta, Canada
                I just have to say that I have had pretty good luck with the polish Autosol. I will post some pics of how blue my exhaust was and how it cleaned up.
                Though many will disagree with me I think that a bike properly set up will not blue single wall exhaust tubes. Mine have been in a non blue state since I polished them, and while I do not ride the miles our southern bretheren do I have put a good many miles on this bike.
                My exhaust does now have a slight (very) gold hue to the upper most portions of the exhaust. I was told that using a polish will cause that.
                The exhaust in the pic's is from the best running bike I have, and I get better mileage than most. So while some may think the single wall tubed headers will blue no matter what, I will respectfully disagree.
                It is unfortunate that it is late and I could only take a pic with a flash as I could show you the color of the exhaust, years after their polish.
                Before polish
                After polishing them.
                2-79 XS1100 SF
                2-78 XS1100 E Best bike Ever
                • donebysunday
                  • Oct 2012
                  • 1737
                  • New Berlin, Wi.
                  Beautiful !
                  Autosol, a product I've not heard of before ?
                  Thank You !
                  76 XS650 C ROADSTER
                  80 XS 1100 SG
                    Rasputin, have to agree for the most part. Quality of the crhoming process have alot to do with whether this happens to exhaust or not. Other factors such as lean or rich can cause this quicker also. Very true, any chrome polish of any brand WILL cause the yellow/golden tint and can be confused with a lean condition. Rich, can attribute to the blue as unburnt fuel is still igniting on exhaust stroke at the head pipe upon escaping. These two pipe cond. are often confused with the lean/rich issue. BTW, those header pipes ARE in nice condition!
                    • Rasputin
                      • 3187
                      Just used plain old Autosol metal polish in a tube like a toothpaste tube with a bit of elbow grease and a lot of Mothers Powerball rotations. Plan on doing another set soon so maybe I will remember to take pics when I do.
                      2-79 XS1100 SF
                      • graybird78
                        • Apr 2003
                        • 360
                        rasputin those pipes look exactly the way mine do. where did u find the polish at.are those pipes jardines?
                        graybird78
                          Hi greybird,
                          single wall pipes discolor as they heat.
                          Yes you can polish the oxide off but it'll soon come back.
                          Polish enough and you'll be down through the plating to the bare steel.
                          And that'll discolor too. Until it rusts.
                          The oxide is also a tune up indicator.
                          Purple/blue/dark straw/light straw fading to clear chrome half way down the first straight length shows perfect carburation.
                          Live with it.
