I found a couple threads on these Mc Master 1mm shims I bought Not sure if I should use them on 1st gear ?
Here is part of one of the threads with a link to it.
Done };~)
I may be wrong in my thinking, but with 6 dogs engaging it and the gear being solid instead of cut-out like the rest of them, they intended this gear to be a bit stouter and handle more stress than the rest. It seems that the washer being thinner may help if it gets 1st closer, but the dogs and 4th gear can only come so far, then they hit that spring clip keeper. So 1st would have to come closer to the dogs. The parts all fit together pretty solidly, so I think that if you took 1mm away from the washer between 1st and 4th, to keep the middle drive gear and 1st from wallowing back and forth, you'd have to put another 1mm washer on the back side of the middle drive between the clip on the outside of that gear and the clip out there to take up the slack. This would essentially move the middle drive gear and 1st gear 1mm closer to 4th.
I wonder if you can buy a 1mm thick washer this size? I'd like to try it sometime. I don't think it would be enough to worry about the dogs and 1st not disengaging... you're not talking much movement. BUT.. there's not much "Meat" those dogs are contacting... so 1mm might make a BIG difference. I just went and checked, and neither washer on either set of gears I have has any wear to it, so it's not like their taking a beating in there.
Any other thoughts?
Link to this thread http://www.xs11.com/forum/showthread.php?t=14621
Done };~)
Any other thoughts?
