Emissions -Help please
  • lazer
    • 37
    • Los Angeles
    [So I took my bike in to transfer the title - spent an hour at AAA getting the run around -sent me to the DMV - spent two hours there]
    Bottom line; any bike manufactured after 78 that's over 50cc needs an emission sticker to be titled in California!
    Help!
    Does anybody know if there was ever one on these bikes- if yes where would it be - if not.....
    Any and all help is appreciated.
    Thanks
    Cheers,
    Lazer
    81XS11H
    why not?
    • 1591
    California DMV http://www.dmv.ca.gov/vr/smogfaq.htm says:
    Does my vehicle qualify for a smog exemption?
    Smog inspections are required unless your vehicle is:
    Hybrid
    Gasoline powered 1975 year model or older
    Diesel powered 1997 year model and older or with a Gross Vehicle Weight rating (GVWR) of more than 14,000 lbs
    Electric
    Natural gas powered with a GVWR rating of more than 14,000 lbs.
    Motorcycle
    Not sure the clerk you got knew what they were doing. If the law hasn't changed then you should be able to Title a bike without an emissions test. Will be interesting to hear from a couple other Calif XSives if that is correct or not. Yes, you are gas powered and Yes, after 1975 but you are Motorcycle which should be EXEMPT according to Calif DMV.
      Look behind the left-hand side cover
      Lazer,
      The Emission Control sticker is under the left-hand plastic side cover.
        That's what you get for living on the left coast.
        • latexeses
          • Jun 2008
          • 1491
          • California
          That is just PART of what we get.
          Everything on hold...
          • lazer
            • 37
            • Los Angeles
            Solved!
            Thanks so much - really appreciated! (well, I appreciate it - the DMV lady was POed that I solved the problem that she couldn't! It pays to know the right people!)
            Cheers,
            Lazer
            81XS11H
            why not?
