Metal Tooth Cable Ties
  • MPittma100
    • Aug 2011
    • 2359
    We all have used cable ties for years and one is just as good as another - right? I don't think so.
    I have had to use metal tooth cable ties on certain equipment that specified them and am here to say that I will not use any other kind. The regular (cheap) plastic tooth ties just do not hold up. They break and/or loosen.
    Metal tooth ties are rated in the number of pounds that they will hold. The tooth itself is made of stainless steel. A smaller one of these will hold much better/more than a larger plastic tooth tie. They can be purchased at Grainger stores, and most of your home supply stores or online at http://www.elecdirect.com, Usually don't find them at automotive outlets. And yes, they cost more.
    I strongly recommend using them over the plastic tooth version for greater durability. They last a lot longer.
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
  • Aches n Pains
    • 349
    • Reston, Va.
    Thanks, MP. Pretty reasonable as well.
    Aches n Pains
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      The ones I have gotten with metal tooth were the fire rated ones and are also made of a stronger nylon. Are these the ones you are talking about. Most times the 8 inch ones are a buck each.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • thibtyson
        • Jul 2012
        • 60
        • Manhattan, MT
        Thomas & Betts makes them and you can probably find them at your local electrical supply house. They aren't cheap and more than likely they won't sell them to you individually. They'll probably make you buy a bag. Also, buy the black ties, they are UV resistant, the white ones are not.
        Current Ride:
        81 XS1100LH Midnight Special
        Tkat Fork-Brace
        Previously Owned:
        79 XS750 Special
        • MPittma100
          • Aug 2011
          • 2359
          Cable Ties
          The http://www.elecdirect.com website has some good prices. They also have a large selection. I've seen them at Home Depot before, but usually order from website.
          MP
          K&N Air Filter
          ACCT
          EBC Front Rotors
          Mike
            Originally posted by thibtyson
            ....Also, buy the black ties, they are UV resistant, the white ones are not.
            The blue ones are nuclear grade... Not that anyone will be stocking them...
            In the smaller sizes (under 1/4" wide), the ones with the metal tang are all I'll use. And a good tip when using them is don't cut off the excess; instead grip it with pliers close to the body and twist it off. The tie will break off flush with the body and not leave a razor-sharp edge to cut you later.
