carbs jetting issue video colortune
  • le_bucheron
    • Sep 2012
    • 45
    • Montreal, Quebec, Canada
    I just did my first ride after tuning. After the bike was warm, it run great. But around 1/4 to 1/2 throttle it coming to back firing. I can run perfectly the bike if during back fire I release a little bite the throttle and twist on again slowly. 1/2 to open throttle no problem.
    Now I have:
    Pilot 47.5 mikuni
    Air jet 190 dynojet
    Main jet 128 dynojet
    Sync and colortune twice
    In the dynojet instructions they say to use 138 main jet. I found it to big... The stage 3 it's for pods mod and after market exhaust. I build my exhaust by using supertrapp headers 4-1, add spliter 1-2, finish it with 2 slip-on kerker serie k from a vmax. I found it more quiet than my cheap 4-1 exhaust.
    I running 2 times short of battery during my test and tune. Also I add a car battery over my balistic one.
    What is next step?
    -Be sure my charging system run great?
    -Use bigger main jet?
    -move my needle clip (dynojet)?
    83 XJ1100
    06 FZ1 naked abarth
      Now I have:
      Pilot 47.5 mikuni
      Air jet 190 dynojet
      What is next step?
      New battery, and check that the voltage is the same AT the coils as it is at the battery, key on both checks. No change should be seen.
        • 8077
        He ain't kiddin'! Do not tear into your carbs before you're sure they don't have an electrical problem. I just went through this with mine. My low throttle setting issues were cured by cleaning a few connectors and the kill switch.
