Holy Balls!!!
I changed the oil and changed the jets back to 145/45 and double checked the float height at 23mm. I was unable to get the filter off as the bolt is probably welded in. I used everything to try and get that bolt to loosen up and nothing worked. I eventually flipped the bike on it side to get more leverage and that still didn't work, but oh well. I had to rig up zip ties to operate the choke because my #1 choke clip screw decided to never come out and I have yet to drill it out and replace it. So she fired right up and started smoking like a chimney and continued to do so for the mile or so until I got on the highway. I noticed a lot of power just waiting for the smallest bit of throttle, but when I got on the highway, HOLY BALLS!!! It still has a flat spot in the midrange, but it will pull all the way to 8000 and quick. Now I understand what everyone was talking about having to hold on.
So I am thinking that the midrange needs to be richened up to match the increased jetting, so 1 notch richer will happen next week. I still need to sync the carbs and set the timing, but I have to believe that it is pretty close to spot on.
How do you guys get off stubborn oil filter bolts?
