Valve Adjustment
  • MPittma100
    • Aug 2011
    • 2359
    Valve Adjustment
    So when should you check valve adjustment? After 25 or 30 years on these bikes should be sufficient, right?
    I was checking the lash on a 1980G with 15K miles. The exhausts were around .005-.006, intakes were .0025-.003. A little tight by the specs in the service manual. My question is should these valves be adjusted? Or run it like it is?
    I am thinking that there is not that much wear here. But what do you guys suggest?
    Thanks, MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Are you talking about valve shims? They should be done every 4k miles.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
      Hmmm... Taking the valve cover off is a giant pain in the butt... I think I'm probably a good 100,000 miles over-due on checking them.
      Since you're there, I'd shim them to the wide side of the spec. They get tighter (Smaller gaps) as time goes on. I simply unbolt the cam I'm working on (One at a time) after finding out the sizes I need. Replace the shims, bolt the cam back down and loosen the other one and repeat.. then throw it back together, being VERY VERY CAREFUL not to drop one of thos little cam cap nuts/washers down into the black hole of the cam chain galley.
      • MPittma100
        • Aug 2011
        • 2359
        Shims
        Where is the best place to buy the shims? Does anyone sell an assortment?
        MP
        K&N Air Filter
        ACCT
        EBC Front Rotors
        Mike
          No idea what happened to the shim library from here or who ended up with it. But most any bike shop that's been around any length of time will probably have them. Just be aware, as I said in another thread, take a micrometer with you. Several bikes (And even cars) used the 29mm shims like our bikes have, but they also made them in a 29.5mm width, and you can't tell the difference with a naked eye... they just won't fit in the shim bucket.
          • LoHo
            • Sep 2002
            • 1342
            • Fresno, CA
            This isn't really really on topic, but why would an engineer think that a cam needed to be designed for 29.5mm shims when 29mm were around? Just to make it tougher on anyone working on an engine?
              I don't know, but if they're anything like the engineers that I work with, they all want to leave their own little mark on the world, so their motto seems to be, "If it ain't broke, screw with it until it is..."
