So when should you check valve adjustment? After 25 or 30 years on these bikes should be sufficient, right?
I was checking the lash on a 1980G with 15K miles. The exhausts were around .005-.006, intakes were .0025-.003. A little tight by the specs in the service manual. My question is should these valves be adjusted? Or run it like it is?
I am thinking that there is not that much wear here. But what do you guys suggest?
Thanks, MP
Thanks, MP
