XJ4Ever Stainless Steel Brakes and Bearing Rebuild
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    3Phase
    Do you remember the lengths of the rear stainless brake lines?
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
      info@xj4ever.com
      Originally posted by TheRev
      3Phase
      Sorry, Rev, honestly? Erm, nope!
      Chacal would be the one to ask just in case there's a change that doesn't get pushed out to his web page.
      For the rear brake there's a three-piece setup with the two soft hoses and the pre-formed steel line, and there's a one-piece hose that eliminates the steel line and the fittings in the middle of the swingarm.
      • mack
        • 2411
        • Ontario, Canada
        lines
        Hi Tony been a long time since I've seen you post. Is this for you r SF rebuild? I can go out and measure mine if you need the length and angles.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
