Everything arrived today and now the fun begins with a metric benchload of new parts!
Front and rear wheel bearings, seals.
All of the parts necessary for a complete brake rebuild including a freshly painted front brake union joint, new master cylinder kits, banjo bolts and washers, Chacal's XJ4Ever OEM-style SS brake lines and HVCycle SS pistons. The K&L brake caliper kits are not shown.
Mike's XS gas cap rubber seals and a bag of spring clips;
1 Quart of Thor Oil's Tire Prep #12 100% Wintergreen Oil.
Upper and lower triple tree bearings and lower seal with a new chrome bolt (new chrome is not as 'bright' as the old chrome) and cover washer. Not shown are two new McMaster-Carr 6975A16 Fixed Hook Spanner Wrenches for Slots, fit 1-37/64" to 1-21/32" (40MM to 42MM) Circle Diameter.
Yamaha rear brake master cylinder kit 2H7-W0042-00 for a 1980 XS1100G.
The old parts are laid out above the new parts for reference.
Wintergreen oil and Xylene mixture to renew the old rubber bushings on the swingarm for the rear brake hard line.
I already painted the front brake union with Rustoleum Satin Black and a sacrificial rear master cylinder is soaking in EvapoRust as I write to get the remnants of the steel retaining circlip out of the piston bore. It will be cleaned, prepped and primered tonight so that it can be painted tomorrow. I want to see how the paint turns out and holds up to brake fluid before I start to take working parts off of Columbo.
