Yup, time fer a build thread "The Mutt"
  • BZ
    • Jul 2013
    • 19
    • Missouri
    go this dirty ol dawg apart and ready for a good scrubbing
    remove tank, Air dam, seat ect... and a few hours of scrubby scrubby
    the frame of this old bike is in exultant shape and all the rubber bushing look in good shape very little ware. Not bad for 47K miles well maintained I gotta say.
    time to remove the rattle can deluxe paint job
    other stuff going on: advice would be helpful
    Removing front tire and replacing-in in progress waiting on tire to come in the mail
    Replace tail light lens- need new lens for left side if any one can has one hit me up
    Air dam- Fiber glass..... how da funk do I get this paint off without killing it? also where do I find a new wind screen, the one on the bike is cut down and cracked.
    Seat- Cover/replace the metal part is good but the seat is made form an old leather jacket... not kidding
    LEDs- one idea it on the front cal to trace the original pin striping with white led strips, tucked under frame will be red green or blue
    Paint Idea's: frame staying Black
    fire engine red tank and air dam is what I'm leaning too, pics links welcome show me what you got! need ideas. (no I'm not going to just google it that spoils all the fun)
    Also: looking for saddle bags, trunk, and mounting gear not really important at the moment.
    found a full service manual online figured I would share: http://www.ringler.us/xs1100/YamXS1100Manfull.pdf
    Cheers.
    Take the wheel to a bike shop, best $30 you'll ever spend
    Same stripper you used on the tank, work small patches & be quick. Better yet, wet sand and paint over what you got
    Easiest way is a Saddlemen's replacement cover
    Now that'd be a unique look. Gotta REAL big Christmas Tree to hang it on?
    I put the comments in blue
    • BZ
      • Jul 2013
      • 19
      • Missouri
      will do
      I'll give the wet sanding a try
      Thanks! ordered
      Yessir!
        Hey BZ,
        I don't have a Fairing, and so I don't know the different models/styles/brands, like Vetter and such. Others will be able to tell you what brand/model it is, and whether you can get a replacement windshield, or if you'll have to make your own out of Lexan sheet, using an oven to heat it to be able to wrap it around/across the old one as a template to match the curvature, then drill the holes, use a jigsaw to cut out the shape. Lexan is stronger and doesn't crack like Plexiglass.
        If you are wanting to save a little $, then take a look at the tech tips, maintanence or repairs, wheels/tires, and see the front tire change pictorial, it's for a special not a standard, but the mounting and balancing of the tire info is the same.
          Hi BZ,
          Your fairing is made of ABS plastic. Wetsanding would be the best.
          Base plastic is BLUE so you will know when you have taken off the paint.
          Windshield is same as Vetter. I am looking for one myself. Should be mounted with plastic (nylon) bolts.
            • 7808
              Hi BZ,
              Mounting a new shield SHOULD be done using Vetter's screw/nut kit. The plastic screws and nuts from the hardware store are NOT strong enough and will soon break,DAHIK. Vetter's plastic screws come with METAL nuts, confirming the quality and tesil strenght of thier screw kit. Just a word of advice, and you'll find worth every penny!
              • BZ
                • Jul 2013
                • 19
                • Missouri
                thanks for the help!
                (off to tech tips)
                • BZ
                  • Jul 2013
                  • 19
                  • Missouri
                  Paint stage 1
                  where the original decal was is going to be black, silver pin stripe
                  • BZ
                    • Jul 2013
                    • 19
                    • Missouri
                    more updates
                    I liked the way it looked with the cherry red so imma let it stick, I finally got my Motorcycle permit so the only thing I'm waiting on is my front tire to get mounted, new tail lights to get here, and Motor vehicle inspection
                    • BZ
                      • Jul 2013
                      • 19
                      • Missouri
                      not done yet just wanted to see what it looks like
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        • Virginia Beach, VA.
                        WOW!
                        I like that red and it'll help you be seen by those crazy cagers!
                        Did you apply a 2 part clear coat to the tank? Hope so, Gas spills will eat it up if not.
                        If those turn signals are LEDs then make sure you swap out the stock flasher with one that will work with LEDs. The stock flasher needs a certain amount of load from the 27Watt bulbs, if you go to LEDs then that load changes and the stock flasher won't flash.
                        80G (Green paint(PO idea))
                        The Green Monster
                        Got him in '04.
                        bald tire & borrowing parts
                        Scarlet
                        Got her in '11
                        Ready for the twisties!
                        81H (previously CPMaynard's)
                        Hugo
                        Cold weather ride
                          Hi BZ,
                          Looks very nice. Just a front wheel and saddle and you will soon be on your way
                          • BZ
                            • Jul 2013
                            • 19
                            • Missouri
                            got the tire back, repack the bearings and tighten Big nut down, turn back quarter turn insert new coder pin right?
                            Nother thought:
                            The Air dam on this Motorcycle is in real poor shape I'm going to leave it on for now but is there a conversion kit for mounting a headlamp and turn signals?
                              Nother thought:
                              Hi BZ,
                              hmmmm? Oh, COTTER pin.
                              First make sure the speedo drive is lined up with the two drive dogs in by the wheel bearing and with the locking lug on the fork leg.
                              Then reef up the big nut. You shouldn't need to back up (or even tighten up) more than 1/12th of a turn to line up the cotter pin hole through the axle and the notches in the castle nut.
                              Tap the pin through so it's eye is buried in one notch; pry one leg out and bend it hard over top of the axle end, clip off the excess. Clip off the other end just short enough to bend down inwards atop the nut's wrenching flat.
                              The other fork leg clamps on to the axle's fat end. You slide that side in or out until the brake disk aligns with the caliper before you tighten the clamping bolt.
                              No conversion kit that I know of.
                              Troll the "XS parts for sale" forum to see what used parts are available.
                              Note that the Standard's front signal mounting adapters are eff nigh unfindable.
                              Or check MikesXS for a generic headlight and fork ears.
