Bench test neutral light switch?
  • MarkD
    • Jun 2013
    • 488
    • N. Michigan
    Thanks for you help, guys, very much appreciated. Replaced neutral switch after my last thread concerning how to check wires, etc. Neutral light still does not go on. Did a recheck by grounding switch wire, and neut. light goes on. Took both switches to bench, used ohm-meter , stuck one contact to where the screw goes in, put other contact on threaded part of switch, no needle movement. Pushed in plunger part of switch ( all the way in) and still no movement on ohm-meter. Is there a sure-fire way to bench test these switches, or is my new one bad, too?? Thanks!
    79 F
    1967 Suzuki X6 Hustler
    1973 Suzuki TM 125
    1979 XS1100 F
    2005 Kaw. Vulcan VN800
    1991 BMW K75
    That's how you test 'em, sounds like both are bad....
    • MarkD
      • Jun 2013
      • 488
      • N. Michigan
      bench test neutral light switch
      I think the website is a little goofed up today, but does anyone have thoughts on how I checked the neutral light switch? Thanks-- seems the site was down all day 'til now. Thanks!
      79 F
      1973 Suzuki TM 125
      1979 XS1100 F
      1991 BMW K75
        • 8767
        You could use a test light to test it, or a bulb rigged up somehow. You never know with those meters. I wouldn't think one of those switches would fail, they usually just leak oil. I got rid of mine, put a bolt in there. Only other thing is the cam plate on the shifter drum that makes the switch's ground contact, not functioning.
        • MarkD
          • Jun 2013
          • 488
          • N. Michigan
          Good idea BPhil--I have a test light, will check tomorrow. Thanks.
          79 F
          1973 Suzuki TM 125
          1979 XS1100 F
          1991 BMW K75
