Had the stock headers off my XJ parts bike ceramic coated. Went to install them tonight with new exhaust gaskets and cylinders 1&2 snugged up fine but 3&4 won't get tight. The nuts hold the flange tight against the machined surface of the exhaust port but the header still wiggles around, I don't dare tightened it any more for fear of stripping a stud. Why would this happen? Will putting a second gasket on do the trick?
Can't tighten headers
Hey there Billy,
Curious, you say STOCK headers, yet your signature says Jardine Spaghetti?? So..are they really stock headers or the Jardines??
Just a stupid question, but you did remove the old crushed exhaust gaskets from the head?? After years and heat/pressure, they can get flattened and squished and discolored so that they can be hard to differentiate from the actual header/head aluminum. And they could offset the alignment.?
If Jardines, then the flanges may have gotten bent?
Are the stud threaded all the way up to the head, or how close is the unthreaded portion is to the inside edge of the flange?
To answer, I think a double gasket would be fine, but as folks say, would be a bandaid type fix...it should fit with just a single gasket.
T.C.T. C. Gresham
I bought the bike with Jardines on it but acquired a parts bike with stock headers...those are the ones I'm putting back on my bike for now.
I think I found the issue. I bought the gaskets on Ebay, said they fit the XJ, but they are very thin with a gray heat resistant coating on them and listing does reference the OEM part #4BE-14613-00-00, $8.79 w/ free shipping. I found the same part # On Georgefix's store but the gaskets appear to be 4-5mm thick.
It appears I need to order these other thicker metal gaskets.Billy
