I measured the OD of the inlet and airbox mouths of the carbs. Well, I say measured... I got the OD of the rubber manifolds where they slide over the carbs, using a Vernier gauge and then deducted the thickness of the rubber x 2. I measured this thickness by pushing a steel ruler across the joint of the carb and manifold. The thickness of the rubber on the inlet side looks to be 7mm and, on the airbox side, 5 or 6mm
I get the OD of the inlet to be 43mm and the airbox side is 55mm.
My gut reaction, having stripped loads of XS carbs is that the XJRs will physically fit. I dunno about the jets etc being right though, although they may be.
I wonder if the rubber inlet manifolds from an FJR1200 would bolt straight onto the XS? I have the FJR ones n my bike as the OEM ones are restricted by reducing the ID.
