xs vs maxim wiring
  • ichiro360
    • Mar 2009
    • 32
    • NEW JERSEY
    xs vs maxim wiring
    my xs got a hole in the engine, due to reckless driving. so i acquired a maxim engine. swap it up and pefect fit. but one on the engine wires dont match up. need help on that. and i forgot how to set up pictures. need help to show the wires
    yamaha xs 1100
    4 into 1
    air cooled
    emco filters
    clubman bars
    one bad mofo riding it
    Upload your pictures to Photobucket and then copy the IMG link of the photo and paste it here in your post.
      I'm assuming you mean a XJ11 AKA 'Maxim'. You are aware that both the charging and ignition systems are different compared to the XS bikes....
      The charging system is a easy fix; use the XJ regulator. The chassis wiring is the same, it's plug-n-play. The XS regulator won't work right with the XJ alternator.... Don't have the regulator? Then you have to swap the alternator on the motor for the XS bits.
      Not so easy for the ignition. The XJ uses it's own ignition box, in fact all the XJ ignition parts are unique, the XS boxes will not work. You have two choices; install the XJ box, and this isn't plug-n-play, there's rewiring involved. Or swap the entire XS engine ignition parts onto the XJ motor, which isn't that tough. It does all bolt on....
      Two more differences, one minor, one major. The major difference is the XJ motor has the YICS system, and that complicates carb adjustments. There's a passage in the cylinder head that needs to be blocked to do a carb sync. Do a search for this, there's much more info elsewhere on this site.
      The minor difference is the XJ doesn't have the oil pressure warning light; it has a 'low oil' light instead. You can install the pressure switch for the light on the XJ motor, or use the existing level indicator, or have both by simply connecting the pressure switch wire to the wire coming from the level indicator.
      • ichiro360
        • Mar 2009
        • 32
        • NEW JERSEY
        cool thanks
        ill try to get some pic up. thanks for the help
        yamaha xs 1100
        4 into 1
        air cooled
        emco filters
        clubman bars
