That Special caliper bolt is an M8 X 1.25 and measures 92.5 MM long.
1979 SF Front caliper removal?
Thanks....
I'll be at the Fastenal store tonite for the new caliper bolts....
TenormanBikes that I have owned and enjoyed...
1964 Allstate 250
1970 Yamaha DT1
1959 Mobylette
1970 Yamaha JT1
1995 Suzuki 80
1978 Yamaha XS650
1980 Yamaha XS1100LG
2005 BMW R1150RComment
Hi Tenorman,
Although I have a different front brake it uses the same bolt.
I found the shoulder bolts at my local Lowes.
Phil1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
No Phil, your bike doesn't have the bolt he needs. Your fork has two bosses that the caliper bolts to. His has one vertical bolt allowing the caliper to swivel.Marty (in Mississippi)
XS650EComment
Hi Marty,
I think you will find the standard caliper uses the same bolt to hold the two parts of the caliper together.
The 2 bolts mounting the caliper to the fork are indeed different being bigger and shorter.
Hmmm. They certainly aren't the same part number. NLA for both. The Special one appears much longer.Marty (in Mississippi)
XS650EComment
Ah! would have to measure for length. The point i was trying to make was availability at Lowes. I have not found my local Fastenal store to be much use for small quantities of anything.
The 92.5mm length might also be a factory bulk purchase length. I think most of what you will find in the hardware stores are 95mm +/- and they will work (just a silly millimeter longer).Mike Giroir
79 XS-1100 Special
Once you un-can a can of worms, the only way to re-can them is with a bigger can.Comment
Repetitive stress...heat, and very hard braking. This is one area where Yamaha didn't OVERENGINEER something!
T.C.T. C. Gresham
Loose bolts is one cause, but poor rotor/fork alignment will also do it. Yamaha is very specific about having the rotors centered in the slots on the forks because this represents the 'centerline' that the calipers pivot on. Have the rotors off to one side or the other and the caliper attempts to 'bend' in that direction. The downside to this is setting your rotor/fork alignment correctly can introduce misalignment/'stiction' into the fork operation, but there's no fix for it; it's the way it was designed....Fast, Cheap, Reliable... Pick any two
