First off you need to take care of the leaking carbs. Don't know if you have the octy anymore but if you do you should not get any gas into the carb with the bike off and the petcock on Prime or On, only on Reserve shoul you get gas. Without the octy you would always get gas on any of the positions except off. If anything else happened you need to fix your octy.
Now you need to look at your carbs. The float valves (little pin that goes onto a brass seat above the floats) should stop the fuel from coming out of the carbs and into the airbox (and/or into the crankcase and then trashing bearings) so something is holding the lost valves open. Often times they get hung up on the bowl gasket and a gentle hit from a screwdriver handle on the bowls fixes it. If that doesn't then the float valve is leaking and needs to be replaced.
For the syncing, be very descriptive for us about your tool, pics would be great.
Then be very descriptive about your process of syncing.
