Boats net
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Boats net
    Looks like boats net got wise to us ? Wanted to order these exhaust nuts but now the min. order costs $6.95 S&H
    Seriously,
    I bought one of these from Boats.net last year.
    $1.49 each and if your order is less than $10 then shipping is only $1.75.
    So let's do the math, $1.49 times 8 is $11.92, which is over the $10 limit, so split it up into 2 orders, 6 in the first order for $8.94 and then 2 more for $2.98. On the second order, you can find something for about $7 and still get the order under $10.
    If the order is above $10 then shipping jumps to $6.95
    They ship USPS and usually get it within a few days too.[/QUOTE]
    Originally posted by GLoweVA
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • tarzan
    • 1700
    • Chandler,Az.
    I found that out last week.So I went to ace hardware and got 8mm hex connector nuts.They are about an inch long.Obviously they won't fit into the counter bores in the exhaust flanges.So I chucked them up in my Lathe and turned one end about 1/2 way back.They work great. Most people don't have a lathe,so you can just grind the points off and achieve the same results.
    80 SG XS1100
    14 Victory Cross Country
      Poor man's lathe
      Hi Tarzan,
      Mr. Bodger has chucked parts in a hand drill or a drill-press and run them against a bench grinder or held a file against them to get a better looking result.
      That was before he found a Bro with machine shop.
      • 650mark
        • Jul 2012
        • 307
        • Mesa, Az.
        having a good friend with a machine shop is "money in the bank" my best friend larry is a machinist in a very high tech shop(they make some parts that are now in outer space) and he does little jobs and makes parts for me frequently. he just turned both my front brake rotors, every other place in town said they couldn't do it. took him about 2 hours of setup time after work one night. saved me a ton of money. all he ever asks in return is a burger and a coke, he's a great guy.
          • 3193
          So where do we ship our parts to get the same deal as you?
            Well, since his buddy make parts that are in space they'd probably have to go to a shack outside La Grange.
              • 3193
              I thought you were talking about a ZZ Top song. http://www.youtube.com/watch?v=Vppbdf-qtGU
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                Bought em
                Bought em anyway, they are still a good deal !
                76 XS650 C ROADSTER
                80 XS 1100 SG
                • CaptonZap
                  • Jun 2010
                  • 1748
                  • Denver
                  And then, to get closer to the OEM item, you take an 8 mm Allen wrench and grind the end to form a broach, and you can broach the outer end of the coupler nut to accept the Allen wrench. Drill the threads out first, to about 8.5 mm. It makes it easier to broach, and you still end up with plenty of grip.
                  When you find you can't pull the broach out after pushing it in, take the nut, with broach still in, place one flat of the nut on an anvil, and pound on the opposite face a lick or two, as though you were trying to flatten the broach. Turn it to the next face, and repeat the pounding. Go all the way around, pounding the six sides, and when you get back to side one, the broach should come out. If it doesn't, you were hitting it like a weak sister, so go back and put some hurt on it.
                  If the zinc plating is good, and your hammer technique is good, you can usually get by without doing too much harm to the plating. It just gets thinner.
                  CZ
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    Seriously,
                    [/QUOTE]
                    Those are pics of MY rusty Nuts!
                    You're right about the shipping, From their site:
                    "U.S. Shipping Rates
                    The lower U.S. 48 states shipping rates are based on the dollar amount of the order.
                    USPS Priority Mail (Tracking Provided)
                    $00.01 - $60.00 total $6.95 shipping "
                    So, next time I buy from them, I'll have to make sure It's a big order (but less than $60)
                    Note: Partzilla, (Boat's sister site) shipping is the same too, however, you can get a 10% discount with a promo code: (I think it's 'sister', but not sure)
                    Then again some members have had bad dealings with partzilla so I think I'll try boats, but still shop around.
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                      • 8061
                      meetsister
                      No bad dealings here. Good selection of aftermarket too!
                      If you can look up part numbers yourself, this place has OEM parts at prices you won't likely beat.
                      YAMAHA SPORTS CENTER
                      Go to "Shop online", then "Parts Finder." You will need to plug in the part numbers as XS1100 is not in their catalog.
                      • MPittma100
                        • Aug 2011
                        • 2359
                        Fix the old ones.
                        Glass bead/sand blast the old ones, paint them silver, and they look just like new. Don't need new ones. This works on the cylinder head acorn nuts as well.
                        MP
                        1981 XS1100H Venturer
                        K&N Air Filter
                        ACCT
                        Custom Paint by Deitz
                        Geezer Rectifier/Regulator
                        Stebel Nautilus Horn
                        EBC Front Rotors
                        Limie Accent Moves On In 2015
                        Mike
