Auto CCT question...
    Hey Howard,
    I think Ras was being a little sarcastic toward your followup comments.
    The stock CCT had a specific travel limit, and when that limit has been reached, the FSM states that it's time to change the cam chain because of the extent of the stretch that has occured to the chain. We have noted that the newer ACCT's have a longer travel and can maintain tension on a chain to a larger extent allowing the chain to stretch even farther than original design spec wear limits. This extra stretch can possibly make the chain more susceptible to total failure/breakage. ALSO being stretched also puts the cams more out of time with the pistons and such, so performance can also be diminished....even though the chain itself is actually QUIET!
    SO...this is why I think Ras was "razzing" you a bit because you seemed to not be heeding the advice about replacing the chain that was given due to the evidence of the oem CCT possibly being at the end of it's limit, and therefore the chain as well!? YMMV! Enjoy the quiet....just hope it doesn't end in a big bang later.
      With apologies to DirecTV
      Hey, Howard, how's it going? You sound kind of depressed!
      When you get depressed you hear noises from your cam chain.
      When you hear noises from your cam chain you buy an automatic cam chain tensioner.
      When you install the automatic cam chain tensioner you gain confidence and ride your XS to Las Vegas.
      When you ride your XS to Las Vegas your old cam chain snaps and you lose all your valves.
      When you lose all your valves you sell your XS to a chop shop.
      Don't sell your XS to a chop shop!
        • 3294
        Scott, good to see you back in the fray... Been so long I forgot I missed whatever it is that you bring to these discussions! LOL! . Great to have you around my friend.
        TopCat, I was more than mildly sarcastic with my remarks to Ras... But...
        I'm the kind of guy that knows when he is barking ip the wrong tree, and also when my cam chain sounds like its barking up a tree.... The new auto CCT has not been the cure all. Seemed like it quieted up initially, but upon a few hundred miles of riding, it is really no different.
        Yeah, get all smug on me boys, I have it coming... I also have a cam chain coming as well for the sake of pro-activity and preparedness.
        Pulling the valve cover this weekend to check the valves and will give the cam chain a good look. What kind of slack should I have/not have when lifting up on the chain? Or would checking the cam alignment marks tell me a similar tale? Just curious what to look for so I can tell you all how out of whack it was.
        Cheers!
        2001 ZRX 1200
        1982 Seca 750
        1983 Nighthawk 550
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          I cant speak for the amount of slack you shoul have between cam sprockets with a properly tensioned cam, but it your chain is stretched you will notice when you turn the crank to the C mark the dots dont line up. They will be "close" but but not on the mark. The more wear and stretch you have the more misalignment you will encounter and the cams will be more out of phase with eachother...
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
            I do not have access to my manuals at the moment. I wonder if there is a spec on the length of the chain from one link to the next like there is on a main drive chain for chain drive bike.
              • 8061
              If you can lift any of the chain from the cam sprocket, it's worn out.
                • 3294
                Given what jetmechmarty said, what is the best way to connect the master link in the new chain with the tightness it will have?
                2001 ZRX 1200
                1982 Seca 750
                1983 Nighthawk 550
                • WMarshy
                  • Apr 2009
                  • 2402
                  • Mexico NY
                  It might have a little flex but shouldnt have enough slack where you can lift it off any portion of the sprockets. If you can, then I agree the chain is whooped and your tensioner cant extend far enough to properly tension the chain any more.
                  You need to remove the tensioner to install the chain. The masterlink is installed prior to retensioning the chain.
                  '79 XS11 F
                  Stock except K&N
                  '79 XS11 SF
                  Stock, no title.
                    • 8061
                    Bonz,
                    With the tensioner removed you will be able to fit the master link with your hands. It's a bit of a challenge as the new chain will be very tight, but you can put it together between the cam sprockets using your fingers and a bit of patience.
                      • 5073
                      That is a good one!
                        • 3294
                        Yeah, that was pure 3Phase!
                        2001 ZRX 1200
                        1982 Seca 750
                        1983 Nighthawk 550
                          Thanks, guys! <sheepish look>
                          Seriously though, you have a low-mileage XS so what... 'happened' to your cam chain? Your XS was pristine when I saw it at Durango and it sounded perfect. The cam chain in that bike should be just getting finished breaking in, not replaced!
                          • Courtney
                            • 542
                            • Nanaimo BC Canada
                            Bonz,
                            And a bit of flesh to the mechanic Gods, and some fancy language your drill sargeant taught you.......
                            Bone stock 1980 Special except for the exhaust and crashbars. Oh yeah, and the scabbard for the Winchester Defender.
                              • 3294
                              3phase,
                              The auto CCT was initially for my 80G that has a cam chain clatter. I picked that bike up last fall as a work in process, and since it went on so easy and simply, I got one for the 80SG you so fondly remember and put that on a few nights ago.
                              The cam chain is for the 80G, not the SG. SG is still getting broke in as you say with just over 20,550 miles after my ride yesterday.
                              Having 3 bikes helps keep the miles down on the SG for sure, and the 80G being the new to me in terms of finally getting it on the road, gets the lion share miles so far this riding season.
                              2001 ZRX 1200
                              1982 Seca 750
                              1983 Nighthawk 550
                              • WMarshy
                                • Apr 2009
                                • 2402
                                • Mexico NY
                                I dont think you should mess with it with only ~25K miles. I have ~52K on mine and no worries. Im sure others can say the same...
                                '79 XS11 F
                                Stock except K&N
                                '79 XS11 SF
                                Stock, no title.
