What size studs
  • 1234loft
    • Jul 2012
    • 77
    • Madison, Wisc.
    What size studs
    I have a set of Kerker 4 into one headers.
    Does anyone know what size studs I need to order to make this work?
    Thanks, JG
    • 8861
    If you have a Standard model XS, you're existing ones should be the right length, if you have a Special, you will probably need to change them, they will be too short.
    • 1234loft
      • Jul 2012
      • 77
      • Madison, Wisc.
      I have a special.
      The PO was using bolts and they only went in a few threads.
      I was curious as to the correct size if anyone had it.
      No one in town has them and I will need to order.
      • 1234loft
        • Jul 2012
        • 77
        • Madison, Wisc.
        Do these look like the correct studs?
        Bel-Metric sells metric hardware & specialty automotive supplies worldwide. Visit our website to purchase metric fasteners, nuts, bolts, screws, washers & more.
          • 7792
          I think these would work better:https://www.belmetric.com/s8x43-metr...p53&cPath=9_71, or you can just go down to the local parts store and buy the smallblock Chevy studs for the "new" engine! cheap and easy.... I know they work as I used them on a '79 Standard WITH the Kerker headers.
          • 1234loft
            • Jul 2012
            • 77
            • Madison, Wisc.
            Got it, thanks much
