As you know, I am new to biking and these bikes.
I have some XSperience with motors in cars, boats and small engines etc, though and I think 'pretty simply'
sometimes.... but here is a suggestion....
If there is no smoke, the oil isn't getting into the combustion chamber (if it is, it is such a small amount that there is no smoke)
If as you say 'oil is pouring out the exhaust' .... I would get the head X-rayed (?) if it is worth the cost to you. It sounds like there is a crack in the head between the exhaust port and an oil gallery.
But first check to see where the Crankcase vent line is routed and make sure it is not kinked, plugged or ???? whatever.
In the Clymer manual,page 45 fig 80, there is a warning about using the valve adjusting tool... "Do not allow the cam lobe to come in contact with the valve adjusting tool as it may fracture the head......"
Of course everything has been torqued properly, in the correct sequence (?) right?
I hope I am wrong after all the work you have done
Work carefully and let us know what you find.
CMA1
sometimes.... but here is a suggestion....If there is no smoke, the oil isn't getting into the combustion chamber (if it is, it is such a small amount that there is no smoke)
CMA1
(total $300 canadian eh). total for engine to date is $694 canuc buc and i did my own valve job, honing, head planing and second gear fix. oops, here i am crying over spilled money. the point is do it right this time and save the $$$. the oven idea is good, the o-ring should be able to take it you can use a little A9 aluminum lube or reasonable facsimile to help it back on the seat. this will stop the harder guide from gaulling up the aluminum. the interference fit should be around .006 so it will be quite snug. if you can find a press it would be better.
