Hey all. I recently posted an issue I was having with my 79 xs11. After rebuilding everything, I finally got the thing running great. But then number one cylinder started pumping oil out the exhaust. Compression was good on all four and it ran like a champ, yet it was dumping oil out the exhaust. No smoke, just oil.
You all gave alot of great tips and ideas, and I finally pulled the head to inspect it. I decided to replace the valve seals again thinging something had to have gone wrong on number one exhaust seal. While inspecting the head very close I noticed something that I had not before. Number four exhaust valve is missing the valve seat spring. Hopefully I am using the correct name for it. It is the washer type seat that sits in the head for the valve spring to rest upon. I am quite suprised as the valve shims are all close to the same and I would think that valve would be way off without that seat. I would also think that at some point it could start chewing the head up. Anyway, does anyone have any idea if this will be a part that is hard to find? Do other models us this same seat? I have had such a difficult time finding parts for this thing, I have some concerns. Can a hardened washer the same size be used? Any info would be greatly appreciated.
