Unknown part left over after reassembly
  • BigDodge440
    • May 2012
    • 4
    • Cottage Grove, Minn.
    Hello all,
    On behalf of my brother who owns a 81 XS1100, he found an extra part left over after minor teardown and rebuild.
    I thought it was a carb jet, but I was wrong.
    Any ideas?
    Thank you.
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Forgot the pic.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
      Originally posted by Tat2demon
      Forgot the pic.
      link at bottom of thread.......
      • Tat2demon
        • Jun 2012
        • 718
        Yep just noticed that :P
        That the air jet from the air intake side?
        Nate
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
        • WMarshy
          • Apr 2009
          • 2402
          • Mexico NY
          Looks like an orifice or some, not a carb part. I've never seen this part... sorry I cant help much.
          '79 XS11 F
          Stock except K&N
          '79 XS11 SF
          Stock, no title.
          '84 Chevy K-10 "Big Blue"
            A ruler or something next to it for scale would have been helpful?
            IT has a central hole like a jet, but not the full head like most of the jets on our carbs. So...even though it has a central hole, it may not be a necessary function? It almost looks like a set screw...like on the carb choke rod??
            Good luck!?
              That looks like a restrictor of some sort; could this have been screwed into a oil passage somewhere?
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                Thats what I thought too, carb jets would be brass and these look like steel...
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                  I agree scale would be helpful. If those were in the carbs, as there are four identicle parts, then I am wondering if some PO used those instead of the right plugs in the early model carbs, or if they were in the mixture screw holes perhaps?? Obvously complete guesses. And yes I see he has an 81, but we all know how carbs get swapped on these bikes.
                    I've had a few of these motors apart.. and have never seen that part, so if it's actually from this 1100 motor, it's a new one on me.
                    Is this 4 screws.. or just one taken from different views like I had thought?
                    • dondons1984
                      • Jun 2013
                      • 153
                      • Walla Walla, Wash.
                      those go to the carbs. I just tore mine down and they go on were the floats are. dont remove the floats. it is next to the other flat head screw that is there. Make sure that they are clear and clean they look a little dirty. But I am 100% sure that those go to the carbs cause I dealt with them yesterday. I dont know the name of them. Again those go to the carbs. If you take off the bottoms of the carbs you will see right in the middle were they screw in cause it will have another screw that screws in adjacent above them that is a flat head. Takes about 10 minutes to do all 4
                      79 SF
                      Wow, did I just give advice? should I be doing that?
                      1983 GL1100 bored to a 1300 sold
                      1976cb750 project gifted to brother
                      1979 xs1100s currently working on
                      Wanting to have that head turner that makes people shut up!
                      • dondons1984
                        • Jun 2013
                        • 153
                        WMarshy those are just really dirty. lol. if you look close you can see brass. Man I almost lost mine yesterday so they are real familiar to me. ahahahaha
                        hahaha
                        79 SF
                          As Steve said, a restricter of some sort. Definitely not a jet of any sort.......sorry dondons.
                          • FJ111200
                            • Oct 2007
                            • 317
                            • Crewe, Cheshire, UK
                            They look like oil jets, similar to those on the FJ, that spray oil onto the crankshaft bearings. They are screwed into the lower crankcase. JAT.
                            Here's one from an FJ.
                            • FJ111200
                              • Oct 2007
                              • 317
                              Possibly part number 13 in this diagram.
                              http://www.cmsnl.com/yamaha-xs1100sh...8.html#results
                              More info.
                              http://www.cmsnl.com/yamaha-xs1100sh...-1_2h71513800/
