Seca Turbo Parts Interchange?
    • 4015
    Anybody know if any parts off an '82 Yamaha Seca Turbo will fit on my XS? Headers, master cylinder, etc.?
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    Header will not fit, spacing on the exhaust ports will be way different... master cylinder might work if they for 7/8" bar. Any MC will work that fits 7/8" bar for that matter... I should say front, rear is unknown and pending bolting pattern...
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
    • FJ111200
      • Oct 2007
      • 317
      • Crewe, Cheshire, UK
      3 ohm 4H7 ignition coils, as long as you disconnect the ballast resistor.
        • 4015
        I have two Seca Turbos sitting in my Mom's garage. I just happened to notice that the Seca's have air shocks similar to the XJ1100. The Seca's are XJ bikes themselves. How do you guys think they will swap onto my XS-F?
        Pics for comparing:
        XJ Shocks: http://www.ebay.com/itm/yamaha-xj110...df4e34&vxp=mtr
        Seca Turbo Shocks: http://www.ebay.com/itm/1982-Yamaha-...e7f7df&vxp=mtr
          Might be a little weak springed since it is from a small bike.
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            Just out of curiosity, can you measure the diameter of the upper metal can, and compare it to the XJ shock. Also, measure the diameter of the shock, (lower cylinder), and compare it.
            If the upper can is the same dimension, and the lower part is the same, I would guess that an adjustment of air pressure could make up any difference of spring capacity, since the area of applied force would be the same.
            Try it out, and let us know.
            CZ
              • 4015
              Hey CZ- Next time I'm down there, I will.
