Has anyone had any experience using the choke plunger dust seals and throttle plate screws that Mike's sells.They are for BS 34 mikuni's on the 650's? Will they fit an 1100? When I asked their tech if they would work the answer I got was "they're only guarenteed to fit 650's". Without stating the obvious I know that they are only guarenteed for the 650's, so whats the verdict do you think they will fit the BS 34 that's on the 1100? Better yet if they won't work where can I source them at a reasonable price. That should be the last piece of the puzzle to get my carbs back together.
Mikes XS parts
I would assume that all the 34s would be the same but thats just a guess. Have you looked at boats.net yet?
http://www.boats.net/parts/search/Ya...cle/parts.htmlNate
78 XS11 "Matilda" 2H7 000364
K+N Air Filter
88 Voyager XII
81 XJ650 Maxim -
Or go here and compare part numbers for the carbs,
http://www.yamahamotorsports.com/spo...starthere.aspx, ignoring the first three letters of the part number.
CZComment
Mike's is good with all other stuff. All Yamaha.
I would trust the parts.Greg
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid.โ
โ Albert Einstein
The list changes.Comment
CZComment
Mikes has always focused on the XS650 stuff. Not shocking they will not comment on if the 650 stuff works on an 1100. Realistically, their quality of parts has been suffering of late. I would make sure it comes from the same manufacturer as other sources before buying. JMHO.Life is what happens while your planning everything else!
78 XS750Comment
The sun will come up in the morning.Greg
โ Albert Einstein
I bought some carb gaskets from Mikes XS and didn't like them and had to change them out.1980 XS1100 SG
1997 Jeep Cherokee 4.5"lift installedComment
The XS650 and XS1100 both have Mikuni BS34 carburetors. They are not the same. The Mike's XS throttle plate screws will work. I can't answer for the choke plunger seal, but it will probably fit.Marty (in Mississippi)
XS650EComment
