1979 xs1100s ignition issue
  • dondons1984
    • Jun 2013
    • 153
    • Walla Walla, Wash.
    So newbie here. I got a pristine 1979 xs1100 that the owner wanted to just get rid of. After goi g through it. (Sat for 17 years but maintained also as in carbs rebuilt and drained and heated storage). I have tried to start it. I am not getting a spark with the grounding tried k of spark plug to the block and screw driver to the block. So do I have bad coils? Cause everything else works minus the headlight. Cause I can go buy new plugs if I need to. I just need to know if I need new coils or not.
    79 SF
    Wow, did I just give advice? should I be doing that?
    1983 GL1100 bored to a 1300 sold
    1976cb750 project gifted to brother
    1979 xs1100s currently working on
    Wanting to have that head turner that makes people shut up!
    Hey Don,
    Glad you got the registration confirmation email and have already posted!! WELCOME!
    Do you have a multimeter?? Secondly, do you still have the OEM fuseblock with glass fuses? They can look good, but be bad, and the thin brass clips corrode, weaken and don't hold the fuse well causing loss of current flow.
    With the bike sitting for 17 years, I'm pretty sure you got a NEW BATTERY for it, so you should have good voltage...the ignition system needs at least 11 volts during cranking/starting. Electrical gremlins are a big problem to getting the bike running, but the coils should not have gone bad just sitting. There are techniques for testing them with the multimeter. See the tech tips, along with downloading manuals from Catatonic Bug's website linked through his profile page here!!
    Also use the multimeter/voltmeter to check for voltage on both sides of the fuses on the fuseblock...suspecting glass fuses!
    That will get you started.
      Hey Don,
      ........and don't look for spark against motor without plugs in caps and grounded to motor. Apparently it can 'kill' the coils.
      • dondons1984
        • Jun 2013
        • 153
        thanks guys for the advice. I am going to be looking into the fuses that are still factory. If it is just as simple as that then I am going to be riding in no time. I still cant believe I got this bike for 250.00 and it looks like it just came off the show room floor
        79 SF
        • dondons1984
          • Jun 2013
          • 153
          also before I forget to mention I guess I am going to have to order a rebuild kit for my left side (sitting on bike) petcock cause I got a small drip that turns into a leak when I turn it to prime.
          79 SF
          • dondons1984
            • Jun 2013
            • 153
            ok so cleaned all the electrical fuses (12v each one). I do have the tank off so I decided to put a little gas in were each spark plug goes. I hit the start button and it took a little but man it coughed like no other and seemed like it tried to turn over. Plus then the headlight kicked on.
            79 SF
            • dondons1984
              • Jun 2013
              • 153
              ok so update. went to go start it after putting a little premium gas in the cylinders then put the spark plugs back on. went to go start it without the tank on since i have a leaky petcock and it almost turned over. now when I try sometimes I get a backfire that sounds like a damn tank went off and makes me jump every time. So here are the questions
              Am I getting spark then?
              Is there something clogging the exhaust?
              I know I am not getting fuel so I am going to focus on the petcock but what does this sound like to everyone else? Do I need to focus on other stuff also? timing?
              79 SF
              • dondons1984
                • Jun 2013
                • 153
                here is a link to the bike when it was in the back of my truck
                Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
                79 SF
                  • 8736
                  If it sat for 17 years, the carbs most definitely will need cleaning, have you done that?
                  Edit: I see that they have been drained, so they shouldn't be too bad. Does it run with the choke but not run with the choke off?
                  • dondons1984
                    • Jun 2013
                    • 153
                    They have been rebuilt professionally
                    79 SF
                      • 2061
                      Rebuilt by who?-best thing to do is get on other parts of this site that deal with carb cleaning and do them yourself.Don't trust anyone to rebuild them as many have seen broken float bowl posts,broken tips of needles and wrong parts put on.For years i relied on a guy by me who had a shop-long story but that shop closed up,and there is not too many places around that have people that can actually work on them that know these bikes.Most shops wont even touch a bike this old.This site is the best for knowledge.
                      • dondons1984
                        • Jun 2013
                        • 153
                        old plugs
                        So my 791100s sat for 17 years. Spark plugs look black and I am wondering can they go bad after time? Is that why my bike tries to start but wont ?
                        79 SF
                          That and carbs plugged up tighter than a drum after 17yrs. sitting........
                            • 9980
                            Triple clean on the carbs and new plugs are in your future.
                            How does that fuel tank look after 17 years? That'll be how those carbs look inside. Clean 'em both GOOD.
                            • dondons1984
                              • Jun 2013
                              • 153
                              Carbs have been rebuilt. So spark plugs are probably my problem?
                              79 SF
