Carb drain bolt leaking. Can't seem to get it to stop.
  • Diskman01
    • Mar 2011
    • 263
    • Sioux Falls, SD
    78E. Carb #1 bowl drain simply won't stop weeping gas. I made a new "gasket" from gasket material last year and it has helped some. I cant see any cracks.. Any input before I get silly and use some sort of sealer on the bolt??
    1) Fire up Internet Explorer
    2) http://www.yahoo.com
    3) type "www.mapquest.com" into the Yahoo search page.
    4) go about day as VP managing multi-million dollar financial contracts.
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    carb bowl drain
    I should have the copper or aluminum ones off the XS650, think they are the same PM me
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    • windysolar1
      • Jun 2010
      • 53
      • United Kingdom
      drain screw
      have you fitted a new o ring seal to the screw ?
      The old ones are the best 9000 miles from new and rising
      got a Honda VF1000f 1984 for the summer in the United Kingdom.Wow its Fast,Too fast for Me
      1982 Xj1100J Maxim US Specfast keeps going
      1984 VF1000F Interceptor UK need repair sticking pro link joint, off the road currently but in a newly built 17ft wooden garage, just got to finish it
        • 8802
        The 78 carbs don't use that type drain set-up, they have an metal crush washer.
        • windysolar1
          • Jun 2010
          • 53
          • United Kingdom
          drain screw
          you keep your l plates for life
          • MPittma100
            • Aug 2011
            • 2359
            Copper Washer
            Buy a copper or aluminum washer from Home Depot, Lowe's, or Ace Hardware. Take the drain screw with you for a match. If the leak is being caused by the gasket, either of these will stop it.
            MP
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              You can find new crush washer at any auto parts store, just take your old one with you or your bolt for sizing. They can be reused but at some point they get too crushed and have to be replaced every once in a while.
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
              • Diskman01
                • Mar 2011
                • 263
                • Sioux Falls, SD
                Sorry for the late reply.. lol. Been a busy evening.
                I *DID* take my bolt and old washer all over town last fall. NOBODY had anything remotely similar. ACE hardware suggested a plain old metric thick washer. lol.
                I have the original crush washer with a hand-cut fiber one above that.
                I will shoot some PMs out at suggested above.
                  • 7766
                  Try JUST the fiber washer, or heat the old crush washer red hot with a propane torch, dunk it in oil, and put it back on. The TWO would allow the gas to seep past the inside threads on the bolt, and leak.
                  • ManagerMike
                    • Mar 2010
                    • 445
                    • S.E. Michigan
                    Ditto, one or the other, not both. Copper or aluminum washer is best, fiber in a pinch. Next trip to the auto parts store, try their misc. brake parts selector kit... think banjo bolt sealing washers, just like on the brake hose fittings.
                    '78 E "Stormbringer"
                    • mikubuilder
                      • Jul 2011
                      • 548
                      • Westland, Mich.
                      also, what might seem like a bolt leak, might be the fuel tee(as in my case), there was a drip from number 3 bowl, but I traced it back to a cracked and leaking tee...
                      Nick
                      1982 Virago 750 (it's alive!)
                      • WMarshy
                        • Apr 2009
                        • 2402
                        • Mexico NY
                        IDK what stores you stopped at but just an FYI, most of the guy at Autozone done know the difference between a dip stick tube and a hole in the ground. The Advanced Auto guys are better and the Napa guys are about the best IMO. I know all of the mentioned have them, you have to go to their hardware section and paw through it. If you just asked the kid at the counter and got a funny look then try asking an older guy working. The crush washers are usually near or on the same rack as the universal oil pan bolts. Hope that helps. I wouldnt waste my time at any of home/hardware stores.
                        '79 XS11 F
                        Stock except K&N
                        '79 XS11 SF
                        Stock, no title.
                        • CaptonZap
                          • Jun 2010
                          • 1748
                          • Denver
                          One other thing you might check is the sealing faces of the bowl and bolt. Someone with a carelessly applied screwdriver, (trying to pry the washer off, perhaps?) could have put a gouge in the sealing face, especially on the bowl, it being aluminum and all.
                          Not a common problem, but while you have the bowl off, it wouldn't hurt to look at it.
                          CZ
                          • Diskman01
                            • Mar 2011
                            • 263
                            • Sioux Falls, SD
                            CZ
                            Ya. I was gonna re-check the surfaces. Possibly smooth them all with some 1000 grit on a sheet of glass. Just to make sure everything is nice and flat.
