HandleBars
  • Douglas Money
    • Jun 2006
    • 180
    • Braidwood IL
    HandleBars
    Have any of you changed the stock handgrips to something a little more comfortable? i.e. softer and fuller for big hands? Also, have you changed to a handlebar that gives a more upright position for a tall person? Thanks.
    1979 XS1100F (runnin the wheels off it)
    1979 XS650 (ran the wheels off it)
    1976 CB550F (ran the wheels off it)
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    A little spendy but you cant go wrong with Kuryakyn Iso Grips. Love em!
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
      I have the Kuryakyn grips and LOVE them. The SG I just sold had mini apes on it. Rode nice, needs a longer clutch cable, brake line.
        I give the Kuryakyn Iso grips another vote. They are larger and more comfortable! I would put them on everything if I had more bikes!
        Little spendy but absolutly worth it!
          Parts-N-More has these for $17. They're probably the same as the ones I got from Mike's XS. They're fat, inexpensive, and work fine.
            I second the inexpensive ones. Have had them on mine since I did my rebuild in 2000. They are holding up okay, but my bike is garage kept, not sure how well the rubber would hold up if stored outside all the time?
            As to the handlebars, check out MikesXS, they have a great assortment of styles. I ride a special, and swapped out the buckhorns for a set of early model GL 1100 bars....better wrist angle and similar spread and rise and pullback. But it can be difficult to tell how they will fit/feel without actually trying them out in person. So...you may want to visit a used bike shop to try them out.
            • DeanR
              • Jan 2005
              • 1499
              • Finger Lakes NY
              Progrips #699 open end gel #714 closed end $8.99
              BMW grips #32721458395/6 $15
              Oury Road Grips
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
              • Tat2demon
                • Jun 2012
                • 718
                Those are what I just took off mine and replaced with the Iso grips. Not a bad way to go at all. I liked them enough to put them on the XJ650 after I I got my Isos. Theyre very fat so pretty comfortable.
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
                  Assuming a bit longer grips being what your after, can change the throttle tube using a Yammy R1 throttle tube in your existing right side assembly. Just use the throttle rotation slot for the cable. The other cable slot is for the return cable on the newer bikes. Then you can use the inch longer grips. The only issue may or may not be the mirrors setting inboard another inch, which can obstruct rear visibility.
                  • ManagerMike
                    • Mar 2010
                    • 445
                    • S.E. Michigan
                    Same set I have. Functional and comfortable, but after five years, (garage kept) the foam is starting to get a bit firm. But hey, for a twenty spot, five years isn't too bad...
                    '78 E "Stormbringer"
                      • 5073
                      I have a set that the foam came off. I still use them like that but I wonder if some sort of golf-club or tennis wracket weap would be good. Anyone tried that?
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        Eenie, meenie, minee, mo,
                        hope that you don't browse real slow.
                        CZ
